Question about Maytag PAV5158A Top Load Washer
The woman reported a popping noise and now there is a "screeching/grinding noise when the tub is turning. It appears as if the tub is "slipping" as it would barely turn loaded. When unloaded it slowly gained speed in the rinse cycle and got quiet at speed. Your thoughts are appreciated
  • 905 Answers
First thoughts are a bad bearing, or the transmission has thrown its clutch surface out the window.
Posted on Aug 31, 2010
Whirlpool type 111 washer drains won't spin. makes loud screeching noise. installed new clutch assembly. still no spin.still high pitched noise (like a belt slipping) but type 111 is direct drive
Belt slipping? is the wash tub free to turn when empty? socks and small clothing items may be jammed in the drum / tub cavity caused by overloading if its stuck. May need to strip machine and remove drum to get them out.
Don't overload machines!
Feb 03, 2018 | Whirlpool Washing Machines
2004 dodge intrepid front end noise
Without a description of the noise, this is impossible to diagnose. Common problem with these vehicles is a "grinding" type noise. This will be a bearing that has gone bad or brake pads that are beyond the service life (louder screeching or grinding upon braking). Popping noises are the CV drive axles are bad (noise is typically louder when when the vehicle is in motion and turning).
Jan 31, 2014 | 2004 Dodge Intrepid
Whirlpool cabrio gas dryer
It could be a bad bearing in the drive motor or on the tub if it is a really high pitch,, or it could be the drive belt on the tub is slipping.
Oct 27, 2013 | Dryers
Very loud screeching noise has tub turn modelfdez16rbso serial3 XDH3299197
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 09, 2011 | Frigidaire Dryers
When the tub is turning it makes a loud screeching noise. The more laundry in it the louder it will screech.
needs these plastic tub rubbers can get at service store for very little money they snap in very easy to do
Aug 27, 2011 | Dryers
The belts continue to make a loud screeching noises when i drive over 55. Sometimes when the car is idling the belts make noise. Could it be the tension pulley.
it could be the tensioner, water pump, alternator, A/C compressor, power steering, or even a really bad serpentine belt. The only way to be sure is to remove the s-belt and spin-check the pulleys and listen for squeaks or grinding bearings.
Jan 13, 2011 | 1984 Buick LeSabre
Our washer is making a grinding noise when the washer drains and when the tub spins any ideas what it might be. Washer seems to work fine just making that noise during a drain and spin cycle.
This sounds like you may have something caught in the drain pump. One of the most common items to get stuck in there is a woman's bra wire. Check it out.
Dec 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Problem with Maytag Washer
Sounds like belt or bearing failure. Possible motor break down. Usually rear panel removal for access. Always unplug unit. Inspect workings for failure. Belt tight, tub turns freely. Usually the motor is the culprit. Tub removal is rarely needed. Search online for specific washer layout.
Jul 10, 2009 | Washing Machines
Maytag PAV5158A Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
