CD Changer will not load disc. Cycles through all 6 discs then shows code 2. The unit is not damaged and disc holder loads as normal. tried a light pressure and a harder pressure when loading, result is the same. Code 2. It is trunk mounted. Kenwood KDC_C699
  • 2 more comments
  • rballman May 09, 2008
    bestdarngood replyed also. But I have another question. He said I have a display button on the radio (not so)unless he is referring to another named button.
    To answer your question. It tries to load all 6 discs in secquence, then stops and shows the cose 2.
    I did not reply to bestdarngood.
    thanks
    If this info helps, the radio model# is KDC-2022
    thanks,
    bestdarngood,
    Thanks for the info. The lens cleaner disc is a no go. I used it in the radio cd and it works perfectly, but not the changer.
    Step 2, For the life of me I cannot find the lens. The case is off as instructed and the front slide door is off. I don't know what a disk clamp is. Looked for 1/2 hour with no luck. Additional suggestions would be welcome. Used flashlight & magnifier.
    rballman
  • rballman May 10, 2008
    bestdarngood,
    Located the lens, cleaned as instructed and reassembled and installed the unit. Result is the same. At this point I assume it needs a new lens to be repaired. It becomes a throw-away unless you can convince me otherwise. thanks for hanging in there. The unit has worked well since new in 2003.
    rballman
  • 298 Answers
Is it loading other disc?
Posted on May 08, 2008
  • 3,037 Answers
Try the following
Step 1. You need a kenwood remote that has aphone style keypad(there are many of them they have numbers and letters like a phone pad)
Step2. Turn your radio on.... it will say ENTER CODE---- and look like this CODE----
Step3. Press and hold the DISP button and the volume up button at the same time for about 4 to 5 seconds, if you did this right you will be confirmed with a beep and the screen will change from CODE---- to CODE.
Step4. Your halfway there once you get to this far... now all you have to do is enter KCAR with the remote like your texting on a cellphone
Step5. To do this press the number 5 button, you will notice that a J will appear on the screen so just press it again and aK will appear to enter the K press the track forward button >>, then press the 2 for C and so on and so on til you spell KCAR...
The 6th and final step... press the track forward button once more to enter the code and there you have it
let me know if this does or doesn't work
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri May 09, 2008
    Changer Error Codes
    • E-00: Poor Cable connection.
    • E-01: Magazine not properly set in changer.
    • E-02: No Disc in magazine.
    • E-03: CD does not have selected track number.
    • E-04: Disc is dirty, upside down or unreadable.
    • E-10: No data is recorded on the MD. The player plays the next disc automatically.
    • E-99: Changer malfunction, disc may be caught in machine or changer requires service.
    So with error code 2 meaning no disc in magazine, that would suggest since you do have a cd in there, that either the laser lens needs to be cleaned or that the laser itself is bad or has a bad connection. either way you will have to open it up to check it out, is there anything to suggest why this started happening?
    To clean the lens follow the below instructions
    Step 1
    Purchase or borrow a lens cleaner disc and try it first. You can find
    these things really cheap at any large department store. They usually
    get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails.
    Step2
    Remove the outer casing of the changer.
    Remove the screws that mount the top casing onto the bottom of the player and slide the top casing off. This will expose the deck,
    which houses the laser pickup lens.
    Step3
    Find the lens. The lens will be glass and under the disc clamp. The lens
    will probably have a blue tint to it. If you are having trouble finding
    the lens, you could shine a light on the components and watch for the
    reflection.
    Step4
    Use a cotton swab and some isopropyl alcohol to gently wipe the lens.
    Just a quick scrub will do. Dry the laser pickup lens with the other
    end of the swab.
    Step5
    Give the lens a few seconds to dry and replace the covering of the player. Test the efficiency of the player. If necessary, repeat the
    process.
    If cleaning it doesn't work then check for a loose or broken connection, let me know what you find, thanks
  • Benjamin Patri
    Please don't forget to let me know your feedback about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, my solution needs to be rated.
    Otherwise, let me know if you have further questions and I would be more than happy to help.
    Thank you
  • Benjamin Patri
    Benjamin Patri May 10, 2008
    do you see the spot where the disc would sit if in the player? If so, then you will find the laser/lens below this area, under the bottom of where the disc would sit. Please take a picture if you still can't find it of the inside and I would be happy to direct you from the picture.
    thanks
  • Benjamin Patri
    yeah, it it has worked well for that long, it sounds like it was a pretty good device, there isn't much else to do, so good luck on getting a new one
I get E-01 error of my cd changer
The fault is actually inside the CD changer, when one disc is selected the changer moves the gearing inside to slot from one CD to the other.
While this operation is happening the selection arm jams !!
Then giving an error at the radio display..
To fix the problem, disconnect the CD changer from the trunk of the car,
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again,
grease the moving parts with light lubricant
Good Luck
Feb 24, 2011 | Mercedes-Benz C-Class Cars & Trucks
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
When i change from radio or single disc to the 6 disc changer there is an error it won't read any discs.... It wont even change discs it won't do anything really...
I suspect that your 6 cd changer is having the fault. The error indicates always a system malfunctioning. From our point of view we can probe into for a solution by the following guidelines.
first of all open the 6 Cd changer from the top. look within to find that the changer is jammed inside. If so slowly tapp while you switch on the power. if the jamm clears and the changer ejects, then open out all the cd's present in the changer for any damage due to heat. If this did not solve, clowing chek for foreign particles/dust that has blocked the loading drive.from completing the cycle so as to reset the mode. normally all errors show because of the processor not receiving the complete cycle signals. hence check for all the moving parts, the drives and the loading mechanism. check also for any linkage damge, any leadd specially flexible line wiring to the motors for an open circuit. Slowly turn the motor drive to intiate to confirm if the motor has failed. Altogether use a multimeter and check in all the sections described.
I hope this helps. Good day.
Jun 28, 2010 | Car Audio & Video
Hi what does Error 03 mean?
My endeavor has done this error 3 a couple of times and the cd changer basically shuts off all lights and won't do anything. Someone on another solution page said to slide a credit card back and forth in the cd opening to fix the problem. I've done this both times and it has made the changer play again as if nothing had happened : )
Nov 14, 2009 | 2004 Mitsubishi Endeavor
The 6 disc magazine will not eject -
Ok..just happened to me. I'm a tinkerer so it's assumed that everything is out of warranty. The low down and skinny is this. The last disc holder is stuck on the metal changer tab, preventing the magazine to eject. 1. Remove the six screws on the left and right sides. 2. Use a small flathead screwdriver to GENTLY pry off the front Alpine CHM-S620 plastic facia.\ 3. On both left and right sides, collapse and push in the rubber suspension mounts. 4. Carefully remove the vertical/horizontal mount springs. 5. Gently pull off the data cable ribbon. 6. Flip over the changer unit. Use a coathanger to gently push the cartridge back into magazine. **You may damage the cd and last holder. Small price to pay to get things back to working order though. You may also have to wiggle the last cd holder to get it over the metal lip. 7. Reassemble in reverse order. 8. Change out that last cd cartridge so it doesn't jam again. Good luck.
Sep 27, 2009 | Alpine CHM-S620 6-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
I own a GMC Envoy and have the 6 disc changer by bose...
You have to push the Load CD button and then it will say load CD 1, then click load again and then it says Load CD 2, it will  beep when its safe to put the disk in!
Mar 16, 2009 | Bose 3 2 1 GSX System
Jensen hd5112 error 2
CD Changer Error Codes: If problems arise during CD changer operation, the following error codes may appear in the display:
ER-1: No magazine loaded.
ER-2: Problem in the disc loading function.
ER-3: Error in the disc loading function.
ER-4: Error in the disc unloading function.
ER-5: Error in the magazine position.
ER-6: Error in the laser pickup position.
ER-7: Error in the laser focus on the disc.
Dec 21, 2008 | Car Audio & Video
Onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
May 07, 2008 | Onkyo DX-C390 6-Disc CD Changer
76 people viewed this question
 Grubhead
Grubhead
