Question about Estate EGD4300SQ Gas Dryer
Timer dial does not move and dryer does not heat
  • Estate Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Timer switch faultynonnwhite knight 44 aw . Will work for a couple of months then not, then start working again for a while then not?
Motor in timer is stopping heats up stops needs new timer
also check even heat board or cycling stats if these stats do not open timer will not move also check for vent restrictions if dryer over heats can also be a issue send me exact model number or picture of Tag will be bedder
Feb 19, 2015 | Abbaka White Knight 44AW Electric Dryer
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
The dryer timer will not advance in permenent press section of the dial. it works correctly on all other sections. i replaced the timer and the problem is still present
could you send the model number and is it gas or electric?when you have it on permanent press is there heat?usually the dryer heats,the heat shuts down and the timer moves,timer stops and the heat comes back on.could have a bad thermostat or thermister but i need the model number to see what is in your dryer
Jun 12, 2010 | Kenmore Dryers
Timer making noise, but not moving
If timer motor is in operation but the dial not forwarding, yes the timer is faulty. plastic gears in the timer eventually ware..
Jun 09, 2010 | Amana LEA11 Dryer
Our Whirlpool Dryer Will not heat at all and not
Your timer may be the cause of both problems. Not cycling and no heat.
Whirlpool makes a excellent dryer and is worth repairing. Replace the timer first. If you still have a heat problem most of the other parts are around $30.
Nov 09, 2009 | Whirlpool Dryers
Dryer does not heat
when your dryer does not heat the timer will not advance, check the heating element and the thermal cut out kit
Jun 25, 2009 | Whirlpool LER4634J Electric Dryer
Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | Roper REX4634KQ Electric Dryer
I have frigidaire electric dryer - drum turns - no heat - timer switch/dial does not advance
replace timer,,than see if it heats,,if you ran this unit with timer not moving,,you made need to change thermerstats
Dec 26, 2008 | Dryers
Will not heat
Your timer has a red wire (marked RH on the timer) disconnect it with the power off of course, check for continuity between this point and all other points on that timer. If you cannot get continuity even while slowly moving the timer manually all around the dial then you have a bad timer. Sometimes you can clean the points on the timer but most of the time you must replace it.
Nov 01, 2008 | Kenmore 63942 Dryer
Estate EGD4300SQ Gas Dryer Logo
Top Estate Dryers Experts
Tim Whalen
Terry Schneider
John Tripp
John Tripp
Are you an Estate Dryer Expert? Answer questions, earn points and help others
