Question about Sony EV-S2000 Hi8 VCR
Brand new Sony EV-S2000 vcr will not play Hi8 tapes
  • 4,234 Answers
I'm not sure what you mean by brand new as Sony has not made these for a while. What exactly is the problem? Is the unit NOS (new old stock) and unused but a bit older? If that is the case, the rubber parts inside may need to be changed. Rubber dries out and gets slippery with age and may not have enough friction to allow the unit to work properly.
Please update this with the symptoms.
Thanks,
Dan
Posted on Aug 31, 2010
Have a Sony EVC100 Hi8 deck . Video is playing ok.
Bad secondary sound head, needs to be replaced.
Oct 02, 2013 | Sony EVC100 Hi8 VCR
I have taken a rarely used Sony EVS2000 out of the closet to transfer some 8MM tapes but after loading the first tape I can't get any motor functions to work. No play, FF, Rewind or eject will function....
sounds like the mechanic is stucked. this happens because due time the used grease is loosing its viscosity. cleaning mechanic and regreasing will help. btw change of old rubber parts are recommended also.
Feb 27, 2011 | Sony EV-S2000 Hi8 VCR
How can I connect a Sony EVS2000 with a LED ( circa 2010) flat screen TV? The input on the LED TV has 5 RCA inlets - 2 audio and 3 video, while the output on the Sony EVS2000 has only 3 RCA outlets - 2...
hi,
u can only connect the sony EVS2000 to a tv which have a composite video input. from ur narration i think the tv has only component video input. if so u can't be able to connect the VCR to the TV.
ok
Dec 30, 2010 | Sony EV-S2000 Hi8 VCR
I have a GE CG818A Camcorder, when I play it it only plays black and white. Was wondering if there is a used Sony or any camcorder that would play my Video8 P6-120MP tape, in color.
I have the exact same camera and same exact same problem. Any analog Video8 or Hi-8 camcorder or VCR will play these tapes.
By using the same cassettes as Hi8, many (NOT ALL) Digital8 (produced by Sony exclusively) camcorders are able to play analog Video8/Hi8 recordings, preserving compatibility with already recorded analog tapes.
you can connect Digital8 camcorders to your computer to download your movies for editing or Internet use.
As of 2008, Digital8 camcorders have been removed from the equipment offered by Sony.
Sep 29, 2010 | Sony 8mm Stantard Grade 120 Minute...
Unit accepted cassette, won't eject
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
I actually own the EV-S3000. Playback problems.
I dont think the tapes is the problem, i think its the heads, if you have not sealed the unit up in a air tight unit while its not been used you can get, condensation in the heads and then that collects dust, then drys on the head, sometimes a wethead clear can clean this off, but if you don't have one of these then you could try alcohol cleaner and a cotton bud. and rubber gloves to touch the head. on the head sock with the alcohol on one bud and leave it to soak for a time. and then clean off with another bud., do the same with all heads and audio and tracking head,then leave to dry. when dry use a nother cotton bud just to check each head is clean. tapes can deteriorate over time but if you have keeped them in a dry damp free aria they should be fine. ...
Jul 04, 2017 | Sony EV-S2000 Hi8 VCR
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Hi8 camera tapes
any brand of hi8 or digital8 camcorder will play back those tapes but sony made a tape deck made to record and play back digital8, hi8, and 8mm tape. you can get here http://www.sonystyle.com/webapp/wcs/stores/servlet/SearchCatalog
Feb 12, 2008 | Sony Hi8 Hi-8 Tape
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony EV-S2000 Hi8 VCR Logo
234 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
