Question about Kenmore Kitchen Ranges
Using automatic cleaning on kenmore stove and stops with F2 flashing?
  • 6,784 Answers
HI. This code is a very strong indication of a high temperature state that has occurred. Also referred to as a runaway temperature issue. The necessary actions are as follows:
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC). The relays are located on the control board.
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
  • NOTE_The Oven control Board (ERC) measures resistance of the sensor circuit and not the actual oven temperature rates.
  • NOTE_The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit or pulled form the back wall.
Posted on Aug 31, 2010
  • Michael Masters
    Michael Masters Aug 31, 2010
    Various oven temperature sensor resistance levels by temp:
    100°F - 1143 ohms
    200°F - 1350 ohms
    300°F - 1553 ohms
    350°F - 1654 ohms
    400°F - 1753 ohms
    500°F - 1949 ohms
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
Older kenmore electric stove
You could try to restart and stop clean cycle. Otherwise unplug stove and remove back panel to access locking mechanism.
Jun 24, 2014 | Kenmore White Electric Stove
Can't get my Kenmore Oven to Stop flashing/beeping F1 after using the self clean. We turn off the braker now, but now my oven is stuck on broil and I cant get it to stop Fl/BP F2. How can I fix this?
probably not. If this is a frigidaire made unit, you will probably have to replace the clock/oven control. That will set you back around $130.
Nov 15, 2009 | Kenmore Ovens
Kenmore 665-9580 error code ''E1 F2''
sounds like you need to replace the oven temperature sensor.
Nov 07, 2009 | Kenmore Kitchen Ranges
I have a kenmore stove and it keeps flashing F2, I have unpluged it, could you please tell me what is wrong with it
is it e1 f2 or just f2. usually f2 means you have a shorted keyboard you need a new keypad.
May 28, 2009 | Kenmore Ovens
F2 IS FLASHING ON STOVE AND BEEPER WILL NOT STOP
F2
During
BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Apr 15, 2009 | Hotpoint RGB745 Gas Kitchen Range
Self cleaning won't turn off
Remove power from the unit for 15 min. It will reset.
Dec 01, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Kitchen Ranges Logo
96 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
