Question about 3M Ergonomic Mouse EM500GPS-AM Small/Medium (70-0710-9882-9)
How do you zoom with the 3M mouse? Need this for autocad.
Hi there, I have a 3M LX451 Keypad mousen and the mouse itself works but the numbers dont work. Is there any downloads I can get to get it to work?
check if the Num Lock is on. This should be the top left button on the keypad. It's a minor thing that's easily forgotten and easily overlooked. If there werent any instalation CDs with your keypad and mouse, there should be no aditional settings. These things are plug and play.
Jan 14, 2011 | 3M (MMMLX451) Mouse
I need driver for 3M EM500GPS 3 Buttons USB Optical Ergonomic Mouse
Should be plug and play for Vista, XP, and later.
Manual and Information here.
Page GB-12 of manual
Mouse Not Detected
Computer ports are improperly
set up (for example, are disabled).
Conflicts among other devices connected.
Installed on an incompatible operating system.
Check with your computer system dealer or
manufacturer if you need help.
Resolve any conflicts among devices connected to
your computer.
Compatible operating systems for the 3M
Ergonomic Mouse EM550 are listed on page 2.
Nov 17, 2009 | 3M em500gps Mouse
Zooming issues with microsoft wireless laser mouse 5000
Use a standart Mircosoft 3 button mouse. I have had the same problem and that fixed it for me.
Mar 20, 2009 | Microsoft Wireless Laser Mouse 5000
I cannot pan with the mouse in Autocad or Revit.
Go to START > CONTROL PANEL > MOUSE ..... Here you will find the Logitech settings. On the BUTTONS tab, you will see a diagram that numbers the buttons on the mouse as well as a table that shows what each button is assigned to. In this table, double click the number assigned to the mouse wheel (usually button 3) and reassign the wheel to MIDDLE BUTTON. This should restore your Autocad pans.
Dec 08, 2008 | Logitech Cordless Wireless Optical Mouse...
LOGITECH 3200 keyboard & mouse
Hi Graham!
Try to disable the "zoom" slider on the left side of the keyb.. (do this in the Setpoint software, coming with the keyb). I have heard of similar strange things happen in other programs when the slider it "graced by accident", (but I do not know AutoCAD 2008/9)
Hi David.
First of, check the batteries in keyb. If prob persists, try to move your USB reciever away from the computer. It sounds like the signal is distorted by electrical radiation. It could also be that your USB bus on your PC is overloaded, in which case an extra PCI USB card would do wonders. You can check this by moving some other USB devices, and see if it helps.
Good luck !
Oct 17, 2008 | Logitech Cordless Desktop MX 5000 Laser
Digitalizzing problem
I have a problem with the same hardware and software. I'm using AutoCAD 2008 and when I trace an object that is 1:1 it come into AutoCAD as a different scale. I have tried different scale factors in AutoCAD and nothing.
Jun 02, 2008 | GTCO CalComp Drawing Board III 34180...
Mouse: Must click 3 or 4 times to "pick" stuff. Highlighting "lets go"
Try compressed air to clean under the button. Alternativly try tapping the sides of the mouse gently on the desk - this could dislodge anything under the button
I don't think its a driver issue but you may as well try it. look for the mouse driver on the 3M web site
Feb 26, 2008 | 3M em500gps Mouse
3M Ergonomic Mouse EM500GPS-AM Small/Medium (70-0710-9882-9) Logo
203 people viewed this question
Top 3M Computers & Internet Experts
Raj Patel
Tom Chichester
james laughton
james laughton
Are you a 3M Computer and Internet Expert? Answer questions, earn points and help others
