Question about Sennheiser RS 140 Consumer Headphones
Sennheiser rs-126 connection
I want to know if i can to connect directly the red and black to the appropriates output audio of Yamaha hd dvd player
  • Anonymous Mar 25, 2014
    Connect the Y cable to the TV Audio output and select speaker TV to external. But still no sound out.
  • 31 Answers
Yes, you may. RCA connections are universal, just don't connect an input lead to an output jack: you might damage the jack.
Posted on Mar 08, 2009
Sennheiser 126 connect to tv
You should be able to hook the tv to the cable box the cable box should have your A/V jacks. If so unplug the PS3 plug in your receiver to the cable box and run the PS3 through the receiver. Also check the side of the tv for HDMI inputs if you have HMDI you can go to Radio Shack and get a converter to go from HDMI into A/V
Nov 07, 2013 | Sennheiser Audio Players & Recorders
I have a new Samsung TV (LED 6000 series). I can not get my Sennheiser RS 120 to connect. I have plugged them into the audio out jacks at the back of the TV. They always worked perfectly with my old...
There is a possibility that internal speakers have to be turned off to direct audio output to the rear connector. You can confirm this by going to the initial set up procedure to disable internal speakers.
Jan 10, 2018 | Sennheiser RS 120 Consumer Headphones
I am attempting to use my sennheiser rs 110 headphones with my lcd-led tv. the componet jacks coming out of the transmitter are red and black. All my componets on the tv are red and white. so when i plug...
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
Mar 10, 2011 | Sennheiser RS 110 Consumer Headphones
My television does not have an audio output so i connected the rs 110 to my cable box and it works fine...however i also have a dvd player connected to the tv video input and for some reason i cannot hear...
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
  1. Look on the cable box to see if there is an option for AUDIO in (should be a pair of red and white RCA plugs)
  2. You want to run an RCA cable from the AUDIO OUT of the DVD player to the AUDIO IN of the cable box
  3. Then select the Auxillary input from the cable box and you should be able to hear the DVD
Alternatively you can run both DVD audio and video through the cable box
  1. Look for DVD IN on the cable box
  2. Connect the audio/video cables from the DVD player to the cable box
  3. To watch a DVD, switch to the DVD input on the cable box
Alternatively you can run the cable box through the DVD player
  1. There may be inputs for AUDIO and VIDEO in on the back of the DVD player
  2. You want to connect the outputs of the Cable box into the back of the DVD player
  3. You can then select the input on the DVD player to control whether you see/hear the cable or DVD
Mar 08, 2011 | Sennheiser RS 110 Consumer Headphones
I Have just bought this reviever (Yamaha Rx-v365)and im just trying to work out how to best connect all my devises. I have Tivo, Lg DVD player with both yellow, red white cables and blue green red cable...
Hi, firstly some terminology:
yellow cable - video composite (worst quality)
white/red - stereo analog audio
blue/green/red - video component (second best quality after HDMI)
You are correct that RX-V365 doesn't do audio over HDMI. Moreover it also doesn't do any video processing, which means composite video input will go only to composite video output (and not to component); compoment input only to component output and HDMI input only to HDMI output.
If you have more devices of same video output (in your example the component blue/green/red), you can connect them to TV via the receiver. But if only one device of same video output, you can connect it directly to TV. There is no reason to go through your receiver for video.
For audio, you can use either the analog stereo white/red cables (rx365 has 5 such inputs) or better use digital SPDIF connection, which is slightly better quality and more importantly supports 5.1 sound. There are 2 types - coaxial (orange RCA plug, can use basic rca cable) and optical (square black connector). Receiver has 1x coax spdif input and 2x optical spdif inputs. Look at your other equipment to decide which cable to use.
For the analog audio inputs, I think you can assign it either to composite video or component video. So for DVD audio white/red plugs, you can choose if either Video composite yellow plug named DVD will be used, or component blue/green/red named DVD will be used.
Jan 03, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have a yamaha receiver with HDMI outputs for direct tv, and a DVD player. How do I hook up the direct tv, HD DVD, and yamaha receiver? Where do the inputs go?
Does the Yamaha have HDMI inputs? Usually you would connect the directv and dvd player via individual HDMI cables to the Yamaha (input)and then the Yamaha (output) to your TV also via HDMI.
Dec 21, 2009 | Yamaha HTR-5640 Receiver
Can't play audio CDs without having the TV on
Your description is not entirely clear, so I have to guess a little here, but I think what is happening is as follows:
1) You are using your DVD player as the source for the CD.
2) Your DVD is connected directly to the TV and the TV then connected to your receiver.
If the above are correct, then the problem is that the TV only has what is called an ACTIVE passthru for Audio signals. This means that the signal is process by the TV and tehn sent to the audio output jacks. With the TV off, the buffer ICs are not functioning, thus no output. Some older sets have what is called PASSIVE passthru.
I don't know your specific DVD model specs, so check to see if you have 2 audio outputs from the DVD (many do) and connect the other audio out directly to the receiver. That will resolve your problem.
Dan
Mar 20, 2009 | Sony Bravia KDL-32V4000 32 in. LCD TV
How do i connect my GPX dvd player to my hd tv? I have Direct TV also.
I also have a GPS DVD Player and Direct TV. On the back of the TV there are slots for AV1 and AV2, I chose AV1. The yellow cable is your video.When placing the YELLOW in the video I noticed the pic was Black and White. After changing it to the slot marked Video Y the color came back. The white and red are audio. I put the WHITE in Audio L and the RED next to it in Audio Pr. Granted I am using a Phillips TV but the concept is the same. Hope this helps. If you don't have sound, switch the position of the Audio (red and white) cables.
Apr 05, 2008 | GPX D1816 DVD Player
Sennheiser RS 140 Consumer Headphones Logo
1,130 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
