Question about Linksys Wireless-G WRT54GS Router (e125894)
The operating range is only @ 30 feet on the second floor and i can only get a small signal within 20 feet on the first floor.
    Scholar:
  • 91 Answers
Upgrade the firmware of the router and use the channel 11 for the wireless connection.
this link should help you
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=e9c2361ee7974d75913e61386a712188_4030.xml&pid=80&respid=0&snid=1&dispid=0&cpage=search
Posted on Sep 15, 2010
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
After turning on the computer (Apple CUBE MacOS 9.1) the vision of the monitor is normal but after a few seconds a screen with a window countdown will start automatically and reads "signal ing"...
you may try this came from manual.
Power Management" "countdown 20 sec
INPUT SIGNAL OUT OF RANGE
This OSD may appear to inform you that the signal being sent to the display is not within its frequency range. In this case, you would need to check the resolution and refresh rate you have your video card set to, and adjust to be within the range of the display
Sep 09, 2011 | LG Flatron L1510S 15" LCD Monitor
The Audio cuts out for a split second every 20-30 seconds.
Check the small signal boards solder connections. The small signal board is the large green circuit board on the right when looking in the rear ( Has all the inputs on it ) Famous for solder issues on the ITC222 small signal boards.slinteriors_22.jpg
Aug 12, 2011 | RCA D52W19 52" Rear Projection Television
I have the cooper K6107v-l motion sensor. Is there a way to adjust the time delay? The device shuts off after about 3 seconds, I want it to stay on for 5 minutes.
under the cover,of the device ,pry with a small screwdriver ,there is 3 controls side to side is the outer or wdth of range then in the center is time ,turn it clockwise you can adjust it up to 20 minutes
Jun 10, 2011 | Cooper Wiring Devices Motion Sensing...
There is a constant beebing in my ear every 3/4 seconds and sometimes my customer can here this too How can i stop this???
Usually, that's an indication that the battery is dying. You need to recharge it. If the headpiece is not holding a charge anymore, you need to replace the battery. Model of battery is CPP-512Q. If the unit is fairly new, you can try reseting the battery by taking off the cap on the headset and then unplug the battery and plug it back in. Good luck.
Mar 03, 2011 | Plantronics CS60 Professional Headset
Connect to network wirelessly with in 20 feet when go down to second floor network indicates no internet , but it can find router , run network trouble shooter but not much , dell has not helped ...
Hello
Signal is either too weak or something is causing it to drop out.You can try a reboot of the router.
If this doesnt work then you may need to get a wireless switch to pick up the signal from the first floor to the second.Which will need to be located in an open area like stairs.Metal decking and flouresent lights can cause the signal to drop.
Or you can buy a cable and hardwire it.Or a stronger router with a better signal.
Nov 02, 2010 | Dell Vostro 1014 Laptop Computer
How do you type a piecewise function into the TI-84?
Here is an asurd example of a piecewise function
Y1=11 for X less than 10
Y1=3 for X in the range [10, 20[
Y1=X+5 for X in the range [20, 30[
Y1=10 for X larger than 30
Here is the screen capture of the Y= editor window.
You have
  1. the definition of the function within a domain, enclosed in () followed by the domain enclosed in ()
  2. a + to introduce the second piece (definition) (domain)
  3. + a third piece (definition ) (domain)
  4. and so on.
  5. Use the [2nd][TEST] key sequence to access the relational operators, less than, greater than, etc.
Here are two screen captures for the Y= editor and the resulting graph. Yoy have to play with the window dimension to display a clear graph. Note : 3 pluses in equation, 4 pieces in graph.
Mar 09, 2010 | Texas Instruments TI-84 Plus Calculator
It seems that the signal is strong next to the router, but drops to 1 bar within 30 feet away? What is the most likely solution.
Routers generally have a strong signal for up to 10 meters. However no obstacles should be in the way. 30 feets is about 10 meters so the router is loosing its signal strength. If you would like to extend the strength of your router you can buy a range expander. This device acts as a repeater of the signal so from 10 meters you can go to 15 or 20 meters.
Mar 08, 2010 | Hawking Hi-Gain 802.11g MIMO Wireless...
Range Vent is only 3 feet from the floor
sUGGEST SAFETY INSPECTION BY LOCAL GAS COMPANY. USUALLY FREE!
Nov 08, 2009 | GE 30" Freestanding Gas Range - White
Cobra PR 260
Dear sir,
Try to operate in channel 1~7 , keep the maximum range extender button pressed for 5 seconds u will hear 2 beeps sounds. If it works Ok or else u need to change your Radio antennae
Sep 14, 2008 | Cobra PR 260-2WXVP Two Way Radio
Linksys Wireless-G WRT54GS Router (e125894) Logo
35 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
