Question about Maxent MX-50X3 50 in. HD-Ready Plasma Television
How to connect antenna to a maxent tv? - Maxent MX-50X3 50 in. HD-Ready Plasma Television
3 Suggested Answers
Highdefjeff
  • 124 Answers
SOURCE: maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Posted on Apr 08, 2008
SOURCE: my maxent tv looks like I am watching tv with
make sure you have a hd receiver and use hd wires to either "hdmi" or red, blue, green wires to connect it to your tv
Posted on Aug 28, 2009
Can you hook up an antenna to a maxent 2007 tv to get free basic television stations
Your Maxent instructions should say. My Maxent is a display, basically a monitor only, that has no tuner. Without a tuner an antenna won't help you make use of the signal. Hope this helps!
Mar 05, 2015 | Maxent Televison & Video
What do i do to watch TV with an atena
Connect the antenna at its socket, select the input to "TV" and then re-tune it. Refer its user manual for more about how to tune it. http://electronicshelponline.blogspot.com/
Mar 31, 2014 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have a Maxent MX-26X3 Television and I cant get it to connect to the local channels when I plug in an antenna. What am I doing wrong?
Do you have a digital converter box? Its a smaller block square box that connects to the wall and the tv connects to the digital converter? I you do not have a digital converter that is most likely your problem. Not a gurantee but since they did the big digital signal switch, you now need these converters. Hope this helped
Oct 26, 2012 | Maxent MX-26X3 Television
Tv is hooked to cable but still gets no picture or sound...only a blank blue screen
Verify that the source is set to "Tuner", "Cable", "Antenna" or "TV". (I don't know which of these names Maxent uses, and the site formerly used for their downloads is now a generic search page.) Make sure the TV format is correct for your region (in the US it should be ATSC, sometimes called HDTV).
If you have a portable TV, bring it over and connect the cable to it to verify that the cable connection is good.
Check the other inputs to verify that the internal video switch is functioning properly. If you don't find a problem with any of these tests, you likely have a tuner problem. Note: do not use a tool to tighten the cable on the tuner connection. I've seen a lot of tuners broken that way, including some with the circuit board ripped apart inside. Use your fingers, and just make the nut snug enough to hold the cable in place and secure the ground connection made through the nut.
Feb 16, 2012 | Maxent MX-42HPT51 42 in. Plasma TV
WILL NOT SHOW PICTURE
there are few reasons for it like signal missing or electronical defect on tv. please check cables for correct connection (example yellow RCA connector is for video etc). if you use terrestrial antenna check cable or even antenna, if satellite is used might receiver or dish problem which have to readjust.
anyway if you are sure the signal source is ok then your tv has better to be checked by a local electronics service
feel free to contact me here under your topic if further assistance is needed
regards
Feb 28, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
Is there any way to connect basic cable to the tv without using a converter box or anything else
Recently, I dropped HBO with my cable company and there dont have a box. Since the Maxent 42 is only a monitor and doesnot have a tuner...there is no where to plug cable from the wall to the tv.
Solution...plug cable from wall to VCR/DVD and then use RCA cables (Red,White and Yellow cables) from output from VCR/DVD. works great.
Nov 22, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
My antenna has a coax-my 50 in Maxent mx50X3 has no coax hook up. How do I connect these two?
That unit does not have a tuner so it does not have an antenna input. You need to connect a cable box, satellite box, VCR with a digital tuner (or an additional DTV box for converted input), or DVR to one of the HDMI, S-Video, or Component inputs to view TV.
Oct 26, 2009 | Maxent MX-50X3 50 in. HD-Ready Plasma...
My maxent tv looks like I am watching tv with antenna and not dish
Aug 28, 2009 | Maxent MX-42XM11 Television
Maxent lcd
Apr 08, 2008 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
Settings
If the Scart/HDMI connections are connected to the appropriate ports on the TV you just need to press the Ext or AV button sometimes marked with a circle with an arrow pointing out C-> this should then allow you to choose which connection you wish to view.
Sep 15, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX-50X3 50 in. HD-Ready Plasma Television Logo
287 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
