Question about Sony KDF-E55A20 55 in. LCD Television
TV Voume and Pictures Goes on and Off
  1. I have this TV for a couple of years and every 20 seconds I will lose the screen and volume on the TV. I have checked to make sure it is not the cable line. Any help I would appreciate
  • Anonymous Jun 13, 2008
    i turn on my tv and about 3 min later i loose picture and sound and every few min turns on 3 min later same thing...........
  • granschwab Jun 22, 2008
    Same problem here. Seems to be worse after the TV has been on a while. I lose video and audio for 15 to 20 seconds and the video and audio will return for a minute or two and then the cycle starts all over. Seems like an overheating problem but the question is, where?
  • 3 Answers
Replacing the lamp will solve the problem. To do this 1st make shure the tv is unpluged from the power surce then unscrew the two nubs on the buttom rear of the tv.One on the left and the other on the right.you dont need a screw
driver for this.(twist with your fingers to unscrew) then go to the front and pull the low silver panel out.Uncrew another short silver door and use the long allen key that came with the new bulb to open the bolt holding the bulb and gently pull out the lamp .Replace the lamp and close every thing back.
Posted on Jun 24, 2008
My LCD tv loses picture for a couple seconds but then comes back on. How do i fix this?
Hi Noah, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=cI2L61dzj6k
Samsung UN46D6000 No picture Sound OK problem FIXED BN95 00497B BN41 01662A
Apr 30, 2016 | Samsung Televison & Video
Losing TV picture, screen goes blank,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Televison & Video
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
KDF E60A20 screen goes blank loses sound for 10 60 seconds
I've had this same problem ongoing for a couple weeks. Finally, tonight it would shut off every 20-30 seconds, stay off for another 20-30 seconds then come back on. It turned out to be my bulb. I blew the TV out with compressed air, removed the bulb and disassembled it. Taking the bulb out of the plastic cage I then remove one of the metal screens at the top of the bulb, it just has little clips holding it in. I took a bottle of rubbing alcohol, some Q-tips and proceeded to clean the inside of the bulb through the screen hole. After cleaning the inside I put the screen back in, cleaned the outside of the bulb with a rag and alcohol, then reassembled everything. The TV is much brighter, I had to turn down the brightness setting and has been running the last few hours without an issue. You can avoid all this by buying a new bulb but I don't have the money right now to replace it and I'm cheap so I'll milk this bulb for everything it has. Heat kills bulbs so if you clean the screens and blow out the TV once every couple months you'll get a lot of life out of it..... I'm almost to 4 years on my original bulb and my TV is on constantly!! Good luck to all!!
Mar 15, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
Menu Trouble
perhaps the volume down button on the TV is stuck. It could be either physically stuck, or the electronic logic could be messed up. Just to rule out a problem with the remote, take the batteries out of it and then adjust the volume at the TV and see what happens.
Sep 07, 2008 | Samsung LN-S4051D 40 in. LCD Television
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
E900
HI, READ PRECAUTION CEARFULLY. RESTORE COMPANY SETTING > LEFT OR RIGHT SIDE ONE VOUME KEY > PRESS IT TO UP SIDE FOR UR VOLUME INCRESS.
Mar 03, 2008 | Samsung SGH-E900 Cellular Phone
Voume problem when playing dvd
the problem try to reprogram the memory ic
May 13, 2007 | Samsung TXG2746 27" TV
Sony KDF-E55A20 55 in. LCD Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
