Question about Samsung HD 40GB ATA-6 | HD040GJ - % Hard Drive
Hard disk problem with my Samsung HD642JJ ATA Device in volume D:\; C: \ how can I check to see if it needs to be repaired or replaced?
3 Suggested Answers
  • 4090 Answers
SOURCE: Hi, I have an error
Leila, repairing a hard drive or replavcing it in a laptop is difficult due the the number of screws and bits and pices one has to remove to get to it. I suggest you take it to a computer specialist that deals with the brand of laptop near you New disk varies depending on size but average about$160.00 and min 2 hrs labor @ $90 and hour. The decision is is it cheaper to upgrade than repair?
Please rate my help++++Thanks for using FIXYA
Posted on Jul 31, 2010
prashant2012
  • 1127 Answers
SOURCE: Have a Dell computer.
Hi
The option is backup take is external drive, how to take the Drive backup.
  1. Go to Disk properties and select the tools and down 'Backup Now" option showing click that option.
  2. Now the new windows will open. click the next and Choose the Backup file option and click "next" now choose the last option " Let me choose " Option and select the driver or document that you take the backup then click Next.
  3. Now you have to give the path where you want to save that backup and give the name.
  4. Then click Next and the backup process is start
When the backup is finish after that you have to format the drive. After formatting the driver you and install the New windows, again go to the D:/ properties and select the "Tools" and click the "backup Now" you get new windows click next the second windows show two option select the "Restore file " option and select the backup path that we take in external drive and click next
now wait few minute you backup is restoring the file..
God Luck
Posted on Sep 15, 2011
How to fix hard drive error message ata device
I think you are talking about Toshiba MK6476GSX, if yes then this might help you
http://forums.toshiba.com/t5/Satellite-Laptops-all-other/Win7-Dectecting-Hard-Disk-Problem-with-TOSHIBA-MK505GSX-ATA/td-p/189018
Jul 20, 2014 | Toshiba Computers & Internet
There is a popup message frequently stating taht "Windows detected a hard disk problem. backup your files immediately to prevent information loss, and then contact the computer manufacturer to determine if...
Click on "Start". Click on "Computer" Right click on "C" drive. Click on "Properties at bottom of menu. Click on "Tools" Click on 1st of 3 options available, check both boxes to scan complete hard disc, this will run a 5 stage correction program upon reboot.
Dec 18, 2012 | Toshiba Satellite L505D-S5983,...
S.M.A.R.T. fault on disk SAMSUNG HM640JJ ATA Device (volumes D:\;E:\).
Replace the drive. Check if it's under warranty.
If you need the data see http://FreeDataRecovery.us
Nov 13, 2012 | Computers & Internet
Have a Dell computer. OS is Win VISTA. Got warning message of potential hard diskfailure. Disk Name is SMASUNG HD642JJ ATA Device Volume: D:\:C: I've tried restoring from a restoration...
Hi
God Luck
Sep 15, 2011 | Samsung HD 40GB ATA-6 | HD040GJ - % Hard...
I want to replacement of my 80 Gb hard disk but I unable to find S/N or P/N in your list My hard disk Model :SP0842N P/N:35201QSS900464 S/N : S0DWJ1BP108754 Please help me for replacemest of above...
You do NOT need to buy a new Samsung disk-drive.
You can buy a replacement from Western Digital, or from Seagate/Maxtor, or any other manufacturer.
Take your current Samsung disk-drive to the computer-store, so that they can sell you a new disk-drive with IDENTICAL data/power connectors (either Parallel-ATA or SATA).
Feb 01, 2011 | Samsung (MP0804H) 80 GB Hard Drive
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Hi, I have an error message on my notebook laptop reading: 'windows detected a hard drive problem (repair or replace disk). Disk Failure Name: ST98823AS ATA, Device Volume C:\. How do I go about repairing...
Jul 31, 2010 | Seagate Momentus 5400.2 ST98823AS...
Hard disk ST9120822AS ATA Device
If the computer cannot Bootup with an error message that hard drive nor detected or no boot device then you could have a faulty hard disk.
Go into the BIOS configuration and see if the BIOS detects the hard disk. If it is not detected then it is probably faulty.
Next reset the ATA data cable on the hard drive and at the motherboard. Bootup the computer again, also check the BIOS configuration again to see if it detects the hard drive.
If it still does not find the hard drive then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer does not detect it as an external hard drive then this proves the hard drive is faulty.
To get your computer working again, replace the hard drive and install Windows together with the device drivers and your programs.
Nov 06, 2009 | Dell InspironTM 1501 Notebook
Computers & Internet Logo
1,013 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
