Question about Maxtor OneTouch II external hard drive 300GB 7,200 RPM - FireWire & USB (E04W300)
Erase and reformat to be compatible with new mac
How do I erase everything off my maxtor one touch and prepare it to use with a new mac osx leaopard intel computer?
  • cmnichol Jan 12, 2009
    I have a Maxtor External Hard drive that was originally formatted for a PC and has been buggy when I use it with my new mac. I want to erase and reformat it for mac, but the permissions say "read only". How do I get around this?
Think I might have solved it myself. Here's how:
Open Disk Utilities and select the external hard drive. Select the "Erase" tab. Hit "Erase" at the bottom right.
That's all. Just dragged a folder onto it and it worked.
Posted on Jan 12, 2009
Hi, i have a Seagate Expansion 1 TB USB 2.0 Desktop External Hard Drive and i want to backup my macintosh by using disk utility. However it seems like as i plug the hard drive in, i cannot put anything...
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in Mac OSX Journeled Format.
6. Click Apply.
7. Done.
P.S. : It will erase everything from your HDD so remember to backup all data before doing this.
Hope it Helps..!!
Jul 13, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
Blinking light in blue
Could be, the product is actually just defective, right out of the box.
An item's compatibility may be limited, too; in that maybe you should
try running your OSX's Disk Utility on that external drive, and if need
be, reformat it to a more compatible Mac extended format. I'd never
take a new 'compatible' hard disk drive at face value, as being so...!
Disk Utility can do several things on a drive; low-level reformat where
it writes zeros over the contents, repair a drive, repair permissions
when an OSX volume is on the drive (as in a backup clone) & etc.
If you can get it erased, reformatted, etc, and it still won't work, check
with the supplier or retailer on getting a replacement under warranty.
Best of luck!
Jun 04, 2017 | Trekstor Datastation maxi t.u SATA 500 GB...
PC/Mac compatability issues
Hi
Is it formatted in NTFS? OSX will read most formats but cannot write to NTFS.
I would suggest that you copy all your files from the drive on to the Mac then use disk utility to reformat the drive in the native Mac format and then copy everything back again.
You may find that once formatted, Time machine will pop up and ask if you want to use the drive as your time-machine back-up. If the drive is the same size as the Mac's drive (or smaller) I would say NO and get a larger drive to use for TM.
If you need to connect the drive to a windows machine at all then don't use the native format (HFS+), use FAT instead. The mac can work with that (although it will probably mess up your files names).
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor one-touch mini won't appear on PC
To isolate the problem, please try the steps below:
1. Make sure that the USB ports of your PC are working.
2. Try to connect the device into different USB ports.
3. Try to connect it into different Windows based computer.
Question: Did you reformat this device using your Mac? If yes, there could be a possibility that the device was reformatted using the Mac OSX (Journaled). This type of format would only recognized by Mac computers.
But if it's formatted using the DOS based system, it would work on both Mac and PC.
Apr 01, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
Reformatting external Hard Drive
click on the hard drive and use the disc manager to format
or right click on the hard drive properties and use the format tab
May 11, 2017 | Maxtor BASICS Personal Storage 3200...
Installing Maxtor onto mac osx
I found the solution here: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SATA_Troubleshooter_-_Mac_OS_X_Installation_Basics&vgnextoid=a0a44a3cdde5c010VgnVCM100000dd04090aRCRD#storage
but short version of it all:
Basically you just need to format the drive to get it working. Open up disk utility. Selecting the maxtor drive on the left in disk utility. Then select the erase tab. Then change MS-DOS (FAT) to Mac OS Extended. Finish by clicking erase.
Mine didn't work at first even though I plugged it in but after I did that it worked. Hope you can get yours working too!
Jun 08, 2008 | Maxtor BASICS Personal Storage 3200...
Computer OS earlier than stated
YOU WILL BE ABLE TO OPERATE ON THE SAME HARD DISK
YOU HAVE TO FORMAT THIS HD FIRST AS FAT 32 AND THEN PROCEED FOR A NEW SETUP OF MAC VERSION .
SO BACK UP DATA IF YOU ARE DOING SO..
May 21, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
New maxtor one touch...no space?
Dear Customer,
you have to this with your mac operating system cause sometimes may happens that in another formated data dont got in mac system ,
so try 1's more time in your mac system & having funn,
THNX
May 16, 2008 | Maxtor OneTouch II external hard drive...
Maxtor 300GB--can't delete or write
You didn't specify if the original PC was Windows or MAC.
Is this USB external used on a PC with Windows? If so is it formatted NTFS? If so, Mac OSX and pretty much everything else but windows NT, 2k and XP can not write to NTFS. OSX and Linux will read an NTFS partition but at this time not write to it. If your drive is formatted NTFS, I would say, go to a windows machine and convert it to a FAT 32 Partition. Most everything will both read and write to FAT32.
Jan 10, 2008 | Maxtor OneTouch II external hard drive...
Maxtor OneTouch II external hard drive 300GB 7,200 RPM - FireWire & USB (E04W300) Logo
482 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
