Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The tub in my washing machine is off center - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
What is the name of the parts that keep a the wash tub centered and balanced and can they break? whirlpool washer LSN1000HQ0
Here's a start.
Type in 'Sears parts direct" on your computer.
Then, type in your model number.
You will get pictures of your machine, every part there is.
Perhaps you can figure which part you will need.
God bless your efforts.
Oct 13, 2015 | Whirlpool Washing Machines
My Washer Baskets is leaning to one side when washing and spinning
Hello penpoint1959 - The tub is stabilized in the center with multiple springs which attach to the base of the washing machine and the frame of the tub. If one of the spring(s) is loose or broken, this may result in the tub being off center. Other possibilities are, the unit is not level and the load of clothing is not balance evenly in the tub. I personally first verify that the unit is level and the unit is being loaded evenly. If correct, and if I was in your position I would contacting a certified technician to move forward accurately and to assist with the repairs.
Feb 17, 2013 | Frigidaire FEX831CS Top Load Stacked...
What is the agitator
The agitator is the large part inside a top load washer tub that moves the clothes around while they wash and rinse.
Sep 26, 2011 | Whirlpool Washing Machines
Can the wash tub be replaced? Where can I buy a new tub?
yes the tub could be replaced here are the part numbers
INNER TUB 131370400
OUTER TUB 131557201
it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
appliancepartspros.com
apdepot.com
Aug 14, 2011 | Frigidaire FEX831C Stack Electric Laundry...
The washing tub shakes on spin cycle, and the tub looks as if not centered in the washing machine
you need to remove the bonnet and make sure all the outside springs are propperly attatched and not broken.there prettycheap to replace and fix.
Feb 16, 2011 | Kenmore Washing Machines
Maytag A806 washing machine leaking from the center,under the tub
The tub seal is bad.
I had the same issue on another model.
You can attempt to repair this yourself. I suggest that you do a search on Youtube to see if this is a job you want to take on. It took me 2 hours to change mine. The seal kit and tools are sold online.
Good luck.
Sep 27, 2017 | Maytag Washing Machines
Maytag HAV4657EWW tub bangs during spin
This washing machine has self-leveling rear legs. Tilt the machine up on the front legs and you'll hear the back legs drop down to re-level itself. Center the basket and restart.
Mar 10, 2009 | Maytag MAT13MN Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
303 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
