Question about Apple iMac Desktop
Discharging A iMac....
Hiya People,
I Have This iMac G3 This Is Giving Me So Much Trouble. It Boots Up With The Screen Yellow. I Know For A Fact That This Is A Loose Connection To The CRT. I Was Just Wondering How To Discharge The CRT. I Know This Is Very Fatal, But I Just Want To Sell It!
Thanks In Advance!
    Scholar:
  • 38 Answers
Discharging the CRT is quite tricky and dangerous, it should only be carried out by a qualified mac tech.
Never work on a mac with the power connected!
The gear you need is safty glasses, ungrounded foam pad, needlnose pliars, wire lead with alligator clip at both ends and a CRT discharge tool (if you do not have a discharge tool you can use a insulated srewdriver attached to a wire lead with alligator clips on both ends)
Use one hand keeping the other behind your back. Do not touch anything with the other had while you are discharging.
Once you have taken off the casing connect the alligator clip from the lead to the ground lug on the all-in-one system. Then slide the discharge tool under the anode cap into the anode aperture. As soon as you feel the metal of the probe touching the metal of the aperture, the CTR is discharged.
Try not to leave the machine open for any lenght of time.
You can find more information on Apples knowldge base.
Posted on Oct 03, 2008
Connecting an external monitor via the imac g3 vga port
The G3 iMac, to my knowledge, does not support an external monitor.
Nov 11, 2012 | Apple iMac G3 Desktop
Apple imac g3 power problems
The power supply is probably bad and needs replaced. You will have to put a meter on the out side of the supply to know.
Oct 07, 2012 | Apple iMac G3 15" M5521 Desktop
Imac 499 mhz boots but no screen display
Hi there
This looks dangerously like a mac I had and it died in my hands because I had it on standby for too long.
Have you looked in all programs and there look for screen-display?
I would try to work it from there. Try to get a brighter screen and so on.
all the best
kollagunn
May 15, 2012 | Apple iMac G3 Desktop
Trying to get an HP 1401 printer to work on an older imac G3 computer. Printer connects to USB port. Cannot find correct drivers qnd don't know how to install drivers on an apple imac.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11543&tmp_task=setupCategory&lc=en&dlc=en&cc=us&product=1103491&key=null&site=null
Nov 14, 2010 | Apple iMac G3 Desktop
How to install a ER 14250 battery on an Apple Imac G3 computer
Please have a look at this link : http://www.scribd.com/doc/103447/iMac-G3-Disassembly-Guide
it's a manual for disassembling the iMac G3. You can use this manual to take apart your computer and fix your batter in it.
If you have any problems in getting it done, please let me know.
Hope this helps, Best Regards
NextDoorNerd
Jul 30, 2010 | Apple iMac G3 Desktop
When I turn on my mac g3 works but the screen stays
Some models of G3 iMac have an external display connector under the rear belly plate. Connect a monitor to this connector. If that monitor shows your desktop, your main CRT is blown. The cost of replacing a CRT in this model is almost certainly more than the residual value of the machine.
May 29, 2010 | Apple iMac G3 Desktop
IMac G3 Not Starting
Hey, RexKing:
Your problem is hard to diagnose with your current description without knowing where the clicking sound is coming from or exactly what it sounds like, but most likely the problem resides either with the power supply or its connection to the circuit boards. If you have access to any scrapped G3 iMacs to cannibalize for parts at an E-recycling depot, you can probably find just about anything you need, as long as you get the right model, as they changed key components a few times, but, like cars, a lot of parts cross over. The exact model description is on the bottom in really fine print.
In any case, you will have to take it apart to check out the power supply and/or other components, which is a bit tricky without a guide. You can find a really comprehensive Apple iMac G3 service document, for many of the later models, posted at this URL as an 11 Mb PDF file:
http://www.scribd.com/doc/103447/iMac-G3-Disassembly-Guide?autodown=pdf
Only catch is that to download it you need to sign up for a free SCRIBD account. (It's a document sharing co-op site.) Hopefully this won't result in years of spam. Good luck, and if you figure out the cause, please let me know. (I have about a dozen iMac G3s that I am gradually refurbishing.)
Ciao 4 nao
WindGod
May 07, 2009 | Apple 15" iMac G3 400Mhz with 128 RAM,...
Removing all personal files from iMac G3
I deleted my internet explore and reinstalled it .
Mar 02, 2009 | Apple 15" iMac G3 400Mhz with 128 RAM,...
IMac G3 unable to boot up
OSX isn't compatible with the older G3's.
Mar 26, 2008 | Apple iMac G3, G4 USB Keyboard 9224078
Apple iMac Desktop Logo
222 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
