Question about HP Compaq Presario F756NR Notebook
When pressing the power button the blue LED on the front for power, hard drive illuminate briefly and then go out. The LED about the mouse pad does the same as does the DVD drive. Does this sound like hard drive issue. Nothing appears on the screen.
    Sergeant:
  • 238 Answers
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery.
    If no, then remove the battery & switch on the PC in AC mode.
  4. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  5. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
  6. If still no display, connect an external monitor, check if display is coming. If Display is coming then your LCD need to replace.
  7. Still nothing change, take it to a service centre.
Posted on Aug 31, 2010
Hp touchsmart 300
From the User Guide at... http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4174137&
The wireless keyboard and mouse are pre-synchronized, for your convenience, to work with your
HP TouchSmart PC. The keyboard and mouse should work immediately after you pull the battery tabs to
activate the preinstalled batteries, and then turn on the mouse (A).
You may need to manually synchronize the wireless keyboard or mouse if they are not functioning.
To synchronize them:
Make sure the keyboard and mouse are next to the HP TouchSmart PC, within 30 cm (1 foot) and
away from interference from other devices.
Keyboard: Press the Connect button on the bottom of the keyboard (B) for five seconds. The blue
activity LED on the wireless receiver illuminates when the synchronization command has been received
and turns off when synchronization is complete.
Mouse: Press the Connect button on the bottom of the mouse (C) for five seconds. The blue activity
LED on the wireless receiver illuminates when the synchronization command has been received and
If this does not work, remove and then re-insert the wireless keyboard and mouse receiver from the back of
the computer and then synchronize the keyboard and mouse again.
Fr
Jun 30, 2014 | Computers & Internet
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
My asus mother board not working
STEP: Ensure Correct Power Button Is Used and Is Not Sticking or Broken. If the power button remains depressed during the power-on attempt, the computer immediately powers off, mimicking a "no power" symptom. Ensure the button is not being held down too long or binding against the bezel or chassis. If necessary, remove the front cover to press the button directly.
2. or else...STEP: Check the Power Button LED on the Front of the Computer (on Blinking yellow)
Initial state of LED at power up.
Indicates system has power, but the POWER_GOOD signal is not yet active.
If the hard drive LED is off, it is probable that the power supply needs to be replaced.
If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed. Look at the diagnostic LEDs for further information. or lese..
3. STEP: Restart the Computer Using the Power Button.Press and hold the power button down until the computer powers off. This should not require more than 10 - 15 seconds.Press the power button to turn on the computer.
4. STEP: Verify the Power Supply Voltage Selector Is Correct for the Region. Verify the setting for the power supply:
*Unplug the power cable from the back of the system. *Press and hold the power button for at least 5 seconds to discharge remaining power.*Inspect the voltage selector setting on the back of the machine (Figure 1). Ensure that the voltage select is set in the correct position for the region the in which the system is operating: For Europe and Asia, the voltage setting should be 230V.In North America, Mexico, parts of Central and South America, and parts of the Caribbean, the voltage setting should be 115V.*Plug the power cord back into the back of the system.*Turn on the power.
STEP: Try a Different Known-Good Wall Outlet.
STEP: Remove All External Devices. Turn the system off.
Unplug everything from the front and back of the system except for the power cord or AC adapter, including: keyboard mouse monitor speakers printers scanners USB devices handheld PDAs external Zip or CD-R drives joysticks/game pads, etc
Attempt to turn the system on.
Blinking Amber/yellow: Initial state of LED at power up.
If all the lead is off, then have the mother board replaced
May 06, 2009 | Dell Dimension 2400 PC Desktop
LAPTOP WON'T TURN ON WHEN I PRESS THE BUTTON
* remove the battery
* press and hold the power button for 10 seconds
* and plug the power cord on a known good wall outlet
* check if there is toggle switch near the bottom of the LCD and it is not stuck
* reseat the memory and other card as wireless and bluetooth
May 01, 2009 | Computers & Internet
I replaced the video card and it still will not boot up.
IF A&B are yellow and C&D are green it indicates a memory error.
If A&B are yellow and C&D are off then it indicates that the computer is in sleep or reduced power mode.
What was your symptoms before you replaced the video card? Sometimes if the power supply is weak or bad or you have a bad motherboard then you get no video output. Check your cpacitors on your mobo for leaking or swelling. Let us know what you find out.
Apr 30, 2009 | Computers & Internet
My computer does not switched on. Power supply is ok but not functioned by motherboard(Biostar). I am expecting your suggestions.
No Power, No POST, No Video
1. STEP: Ensure Correct Power Button Is Used and Is Not Sticking or Broken. If the power button remains depressed during the power-on attempt, the computer immediately powers off, mimicking a "no power" symptom. Ensure the button is not being held down too long or binding against the bezel or chassis. If necessary, remove the front cover to press the button directly.
Apr 29, 2009 | Computers & Internet
Won't boot
Apr 26, 2009 | Computers & Internet
Dell Power Up Problem
Apr 25, 2009 | Dell Inspiron 530 Desktop Computer
Desk top
Apr 05, 2009 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
Shuttle X PC - HD + Power LEDs briefly illuminate, no boot.
It sounds like you have a bad power supply. It will store up a very small amount of energy (enough to run some LED lights) but not enough to power up the system. That's where I would look. If that is not the problem, then I would look to the capacitors on your motherboard. Good Luck!
Dec 02, 2008 | Shuttle Computers & Internet
HP Compaq Presario F756NR Notebook Logo
162 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
