Question about Toshiba Televison & Video
The power button is depressed, and nothing whatsoever will respond on the DVD player--open/shut, load, play, etc. My dad probaby pressed too many buttons at once as it is slow loading. Even if it is not fixable: I need to get the thing open because a DVD checked out from the library is inside.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To take out the DVD locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer. Insert a stiff wire—such as a straighten paperclip or safety pin—into the hole, then push gently and the drawer should open partway. Gently pull the drawer the rest of the way open and remove the DVD and see if there is a problem with it. Please do accept the solution if the issue is resolved or post a comment with the complete model no# for further assistance.
Thanks
Rylee
Posted on Aug 31, 2010
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
Load disc, unit tries to load & play, unit shuts off. Turn power on to set time,etc,machine shuts off.
Laser pickup unit fault. The unit alongwith its flat connecting cable should be replaced. Contact any service technician. Electro help
Feb 23, 2015 | Samsung DVD-V2500 DVD Player
Unit model D-C350/XSA only opens region 4 need to also to open region 2 DVD's
When I was with Samsung NZ, the following was how we multizoned our DVD (Region 4) players:
1. Turn on your player, but ensure no disc in machine - screen should show "No Disc"
2. Turn on your TV and select your DVD input (as if you were to watch your DVD).
Using your factory supplied remote, press the following buttons:
3. Press the Repeat (or Repeat A-B) button
4. Press the following button sequence: 7, 6, 8, 8, 4, 9 (you should see the number '9' appear on screen - this means 'Region Free').
5. Press the Open/Close button (to open the tray)
6. Press the Open/Close button again (to close the tray)
7. Press Power OFF (to shut down your DVD player)
8. Press Power ON (to turn on your DVD player)
9. Insert Region 2 disc and wait (up to 1min) for firmware to respond and read your disc
If this fails, try procedure again, except for Step 4: change the last number (instead of 9) to '2'.
Let me know how you get on.
Cheers,
Scott
"If this has helped you, please be kind enough to leave a testimonial rating"
Jul 09, 2011 | Samsung DVD-C350 DVD Player
CD player just stopped. Will not respond. Will not open when insertion button is pressed, It just keeps indicating the functions (load, open, etc) but doesn't do anything at all.
The loading motor drive is faulty or the mechanism is jammed. You will have to remove the top cover and check for voltage to the load motor when the open button is pressed, if voltage is present , then motor can be faulty ,jammed. remove , replace or reset.
If there is no voltage press on connectors from the motor drive IC, check voltage here, use a soldering iron to touch up .
if not the drive IC control inputt must receive signal from processor control. If yes then the drive IC can be faulty.
Sep 18, 2010 | Samsung DVD-V4600 DVD Player/VCR
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
Jul 25, 2009 | NexxTech DP3222 DVD Player
Door on DVD player
The drawer seems to hang up when it sits closed for a while. I found that using a very thin but rigid metal item such as a nail file under the leading edge, allows it to open with the first press of the  open/close button. I load the DVD, press the open/close button and it closes and stays shut.  After I submitted my problem, it occured to me that the reason for the door to continue to open and  close, was the repeated pressing of the button. The door was merely responding to each time it was "called."
Jan 15, 2009 | Sanyo DVW-6000 DVD Player/VCR
Brough DVD's from america. Wrong region for Australia. I have a Samsung DVD P181/XSA player. How can I play my dvd's. Is there a way to break the region code on my DVD player?? Thanks Sylvia ...
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT (do not confuse this with the A-B button) then the following codes for the required region the player is already set to (region you bought the player in) :
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 0 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 .
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
OR
<DVD> ; press DVD button
<0><0><0><0><0> ; enter 5 times 0
<repeat> ; press repeat button (careful, not <repeat A-B>)
<5 digit code> ; see below, depends on region the player is currently set to
<0 for region free, 1-6 for other region> ; select new region
<open> ; open tray
<open> ; close tray
Now power off/on
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Note: reset player by powering down and simultaneously pressing <power> + <play> until display shows 'reset'.
Jul 30, 2008 | Televison & Video
LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
Dec 01, 2007 | LG DV276 Recorder
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
