Question about Apple iPod nano 3rd Generation
Ipod 3 generation 4gb
I can't unlock my volume limit combination i try putting the password in,but it didn't work.. Can you help me on what to do for this issue?
  • Apple Master
  • 13,433 Answers
Under settings all it will show me is language there is no volumn setting-my sound is not working correctly
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
Oct 17, 2012 | Apple iPod nano 4th Generation
Volume limit password reset on ipod nano
Hi
How to Unlock iPod Volume Limit
Your iPod volume can be limited, and in many instances, a PIN number will be necessary to remove the limit. If you've forgotten or misplaced your PIN, you can still unlock your iPod volume limit using your computer.
1 Connect your iPod to your PC. Make sure your hidden folders are visible.
2 Navigate to the "iPod_control" folder. This will be a hidden folder. Once you've found the "iPod_Control" folder, navigate to the "Device" folder.
3 Locate the file named "_volumelocked" in the "Device" folder. Delete this file.
4 Eject and restart your iPod.
5 Navigate to "Settings" on your iPod. Select "Volume Limit." You'll be able to reset your volume limit with a PIN or password.
Tips & Warnings
Do not listen to your iPod at high levels for long periods of time; doing so can damage your hearing.
Nov 23, 2011 | Apple iPod nano
Dont know the code to unlock my ipod screen and volume limit
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you cannot remember the passcode, you will need to restore your device using the computer with
which you last synced it. This allows you to reset your passcode and resync the data from the device
(or restore from a backup). If you restore on a different computer that was never synced with the
device, you will be able to unlock the device for use and remove the passcode, but your data will not
be present Follow the steps that i have outlined below. If this does not completely help your situation please
let me know and i will be glad to assist you. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to manage
its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features
again. if that does not work you can restore your iPod to factory settings using iPod Updater. Please note
that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is
to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Jan 04, 2010 | Apple iPod nano
CANNOT FIND UNLOCKING CODE FOR VOLUME LIMITER ON IPOD CLASSIC BLACK 120GB
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you need further assistance please feel free to follow up with a comment and i will be here to
Jul 15, 2009 | Apple iPod classic MP3 Player
Volume limit unlock code
Apr 17, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod nano volume locked forgot password
Basically you cant unlock the voulume if you dont know the password. You would probably have to reset your iPod in order to adjust your volume and when you put a new password in be sure to remember it.
Feb 25, 2009 | Apple iPod nano 3rd Generation
Cannot rember the combination to unlock the volumeon a iPod nano.
plug your ipod into the computer and reset your ipod and then you can unplug the ipod and it should work x
hope this helps x
Feb 17, 2009 | Audio Players & Recorders
I forgot password of my ipod model no: A1137,2 GB
HELLO!!!!
I've been using iPod nano for 1 year.I forgot password for volume limit lock. so i can't change the volume.Plz tell me how 2 unlock the volume limit. Reply @ early as possible.
Jan 10, 2009 | Apple iPod nano
Ipod Nano can't unlock volume lock
on my ipod the volume limit is a software setting in the menu that does not require any kind of passcode so you have me a bit confused as to what you are asking
Oct 13, 2008 | Apple iPod nano 3rd Generation
Unlocking the volume control on 80G Classic ipod
Heres how to unlock the volume control, Don't listen to music to loudly. It will destroy your hearing.
open my computer and then
  1. Enable hidden folders.
    Go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". I honestly do not know how to do this on a mac. I'm simply stupid.
  2. Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
  3. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds.
  4. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Apr 19, 2008 | Apple iPod classic MP3 Player
Apple iPod nano 3rd Generation Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
