Question about Kenmore Elite HE4 Electric Dryer
MY FRONT LOAD DRYER IS EXPERIANCING DIFFICULTY IN TURNING THE DRUM WHEN STARTED. UNIT WILL TURN ON, HOWEVER THE DRUM MOVES VERY SLOWLY OR NOT AT ALL. PROGRESSIVELY GETTING WORSE!!! ANY IDEAS????
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Either bad motor or loose belt...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
I was drying rugs and one of the rugs got caught and the drum stopped turning. The power comes on but the dryer drum will not turn.
Hello, one possible cause of dryer drum not rotating is the rugs stuck between the drum and front panel.Secondly, maybe the dryer belt dispart.
Jul 31, 2013 | Sears Kenmore Elite Gas Dryer Front Load...
HI MY AMANA DRYER HAS A HARD TIME STARTING AND AFTER A FEW MINS. STOPS
I am a little puzzled! Normally the difficulty is with startup rather than stopping after starting. Are you sure that the drum actually turns or maybe it just sounds like it is turning? If it never actually turns then it is probably the belt or the motor. You can make sure by placing only a few items in the dryer (try a couple towels or different colors) place the towels inside, (pay attention to where they are) begin the cycle, open the door to see if the towels have changed position. If the drum has been rotating then try adding a few more items to see if things change.
If the drum does not turn at all it maybe the drum belt. If, as you increase the load, the drum has difficulty starting then it is probably the motor or a control circuit. Hope this helps...Good Luck. Douglas
Jan 28, 2011 | Amana Dryers
My front load washer is making a loud noise and think it is the motor, i took the front bottom panel off and the sound was coming from the what looks like motor i guess not sure what to do
Remove the rear panel . remove belt . turn drum pully if you hear any noise it is the rear drum bearing and seal . Reach inside drum from front and lift up on inner drum. If this drum moves up and down or side to side you will also need to replace the inner drum. If turning the drum is silent try turning the motor if it makes a noise replace the motor
Oct 29, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidare ftw 647ghso thumping sound in one spot when i manually rotate drum sounds like its rubbing on something
Suspect a bad drum bearing or bent drum bearing shaft. When you rotate the drum, look for movement of the drum up or down while turning. If the drum moves suddenly, suspect the drum bearing. If it slowly moves up or down during turning, suspect a bent shaft on the drum. In either case, it is a major teardown to remove the drum from the outer drum case. If still under warranty, take advantage! Hope this helps!
Mar 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Unit shimmy's across floor
Remove the two support bars from below the washer drum from the front as instructed in the installation manual
Jan 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Drum having a difficult time spinning
YOU'LL HAVE TO OPEN IT AND CHECK THE FELT SEAL IN BACK OF DRUM. THE DRUM ROLLERS. AND THE FRONT SHROUD SEAL.
Apr 13, 2009 | Dryers
Gas Dryer won't start / run
The motor is overheating and shutting off on overload internal. I would run a load and then check your temperature on your motor you will probably feel the excessive heat on the motor.
I would suggest replacing the motor or at that point buy a new dryer.
Apr 08, 2009 | Dryers
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
I have a fridgeair front load stackable dryer. The dryer tub has problems getting started rotating. At times it also makes loud noises coming from the back center of tub. In order to get tub started...
Frigidaire Dryers use a ball and socket in the rear to support the drum. The socket is made of a Teflon type of plastic that will wear out when the grease is no longer present. By now, the ball of the drum is probably grinding away at the metal support for the socket, thus the loud noise. At the same time the front seals are probably worn out. These two things combined is causing alot of friction keeping the drum from turning freely. The parts required to fix these issues are not that expensive. Getting the dryer apart to replace these items however is time consuming and easier with two people.
The top panel, control panel, front panel and the drum will all have to be removed.
Jun 08, 2008 | Frigidaire Dryers
Kenmore Elite HE4 Electric Dryer Logo
105 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
