Question about Sony Cybershot DSCW310 Digital Camera
My brother dropped the camera and the shutter wouldn't close, so i forced it down, and now it wont come out. what should i do?!?!
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 31, 2010
How to release a stuck sutter on canon 400d
Wow, four days ago.
I would think that the camera has dropped the shutter by now.
There is a mode in the camera that holds the mirror up out of the way for sensor cleaning but this is defaulted as soon as the power is shut off and then turned back on again.
Or the camera was set in manual mode "Bulb" and is waiting for the next command from the photographer to "drop" the shutter "takes a second press of the shutter button.
The lens may be loose (unlocked) and giving a bad command to the camera.
The Canon 40D has a shutter capable of 60,000 actuation so if you are close to this I'd say the shutter has been shot out of it.
Also sometimes the shutter release button sticks and gives the feeling or appearance of a stuck shutter.
Shutter switch also known as a release button have been an issue sometimes where dirt and oil from a person hands get down into the button.
To release shut the camera off, take the battery out, remove and reinstall the lens, shift the taking mode to "P" program or full automatic green box.
Apr 29, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Assistance in using the P for taking pictures How do you use the dials to determine a good picture.
The settings depend on what you're trying to say with the picture. You probably wouldn't want the same settings for a portrait as you would for a landscape. Two photographers at the same place and time with identical cameras probably wouldn't use the same settings, as each photographer has his/her personal style.
In the Program mode the camera select the shutter speed and aperture it deems optimal. You can turn the command dial to adjust the exposure, increasing the shutter speed and opening up the aperture, or decreasing the shutter speed and closing down the aperture by turning it the other way. Either way, the exposure itself remains the same.
If you're taking a landscape picture, you'd probably want a small aperture to get the maximum depth of field. If you're taking a portrait, you'd probably want a large aperture to blur the background. If you're taking an action picture, you'd probably want a fast shutter speed to capture the action. Of course, those are just guidelines. Sometimes you want to blur the action, or throw some portion of the picture out of focus. It's up to you. You use the settings to take YOUR picture.
Oct 24, 2010 | Nikon D90 Digital Camera with 18-105mm...
Hi my camera will not take any photos, its just blank, however i able to still see the photo's i took before it stopped working. i borrowed it to my brother and he beleives one of his friends managed to...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Half the lense shutter will not close
It might need cleaning. You can try these:
1. Start and shut down the camera a few times to see if it shuts down itself.
2. If that didn't help, try this: you should be able to see the edge of the shutter if you look carefully towards the corner from where it was supposed to drop down. Get a pin or a needle, get a grip on the edge of the shutter with the pointed end and pull it down.
3. Clean it - Get a lint free cleaning cloth, dampen it with a lens cleaning solution and wipe the surface of the shutter. When still wet, start and shut the camera a few times. Repeat step 2 if required.
Oct 21, 2009 | Kodak EasyShare C613 Digital Camera
When i turn on the camera the shutter closes, when I turn it off, the shutter opens
I dropped the camera and now the shutter opens when turning off & closes when I open the camera. But when it is open, the shutter will open a bit making it impossible to take pictures. What should I do or where do I take it for repairs?
Tks, Ruth
Sep 11, 2009 | Sanyo VPC-S500 Digital Camera
LCD monitor is black
Sep 07, 2009 | Canon PowerShot SD890 IS Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Canon utilty program freezes then wont close when remote shooting
Check to make sure you have the latest updated software and firmware. You can check at
http://www.usa.canon.com/cusa/support
Mar 12, 2009 | Canon EOS-5D Digital Camera
Re: Shutter Wont click
Hi , check everything set c amera speed to 60/seconds auto or manual / check also the the camera shutter blade , open the lense and close to activate the shutter blade .
Feb 17, 2008 | Nikon F80 35mm SLR Camera
Sony Cybershot DSCW310 Digital Camera Logo
96 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
