Question about Dryers
I have a kenmore 80 series gas dryer that wont heat. I am looking for the igniter but cannot locate it. Is it under the top?
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It is in the bottom under the drum...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
My kenmore 80 series dryer wont heat up how do i fix it
could be the igniter or thermal fuse if you hear the gas valve click open and there is no glow inspect the igniter for a hot spot or white spot where the brek occured,some dryer will spin but not heat up if the thermal fuse is blown
Mar 20, 2010 | Dryers
Kenmore series 80 Gas dryer doesn't heat
Look for extreme fluff buildup inside and outside causing air restrictions. check your fusea5500f3.jpg
Mar 17, 2010 | Kenmore 64742 Electric Dryer
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Kenmore dryer not heating
Check the following-- Gas valve coils Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Jun 05, 2009 | Kenmore Dryers
No Heat
Hi, I worked on one of these yesterday and have found that the thermal fuse blows first. If your dryer has the lint filter on top then the thermal fuse is behind the back panel and is located on the same duct as the lint filter.It will usually have blue wires on it instead of black or red.
Oct 17, 2008 | Dryers
Kenmore 80 Series Model #110.74842400 Series MR5112733
There's a few things on this dryer that can stop it
from heating. 1st thing your going to need is an ohm meter, your testing simply for continuity. The main items that cause no heat at all on this gas dryer is the igniter on the gas valve, the thermal fuse located on the blower wheel housing the thermal cut out located on the burner box or the flame sensor on the burner funnel and lastly the coils on the gas valve. the sequence is from most too least common. Of course unplug it and shut the gas off.
Jul 30, 2008 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Open Questions:
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
