Question about Sony Video Cameras
Hi, I need a replacement Firewire port for my Sony HVR-HD1000U HDV Camcorder. Do you know where I can source one?
  • crichards573 Aug 31, 2010
    I don't know what type of board (I'll ask my teck tomorrow) but it has HDV1080i Mini Divi on the cassette compartment, and has a 6.1 CMOS.
    I don't know if this helps, but I'll try to send more info tomorrow.
  • crichards573 Sep 04, 2010
    Nicely done!
  • 10,594 Answers
Can you tell me what board is written on it, like its JK board or JS board etc.
I have service manual of this camcorder and will provide you part number info, just let me know board name/ number.
Thanks.
Posted on Aug 31, 2010
  • 5 more comments
  • Shahid Electronics
    Shahid Electronics Aug 31, 2010
    OK, I want to make sure that I'm giving part number of required board and there is no confusion.
  • crichards573 Sep 03, 2010
    I couln't reply earlier because I couldn't pin down my guy.
    However I was finally able to do so this morning and he says that he can't find out what type of board the cam has, since it's not listed at his source.
    He however suggested that you can send me a copy of the info you have (for multiple Ports/Boards for the HVR-HD1000U), or send me the part numbers. From this he may be able to determine the correct part I need.
    I hope this makes sense!
    Shahid Electronics Sep 03, 2010
    Is it DV/ iLink port (IEEE1394) of camera that you are looking for part number?
    Yes, it is
    OK, it calls HP-150 BOARD and its part number is as follows:
    A1438710A..... HP-150 BOARD, COMPLETE
    It has 3 jacks, Lanc, Headphone and HDV/DV
    Hope this will help you.
    Thanks.
    Do you know where I can buy one?
    Shahid Electronics Sep 04, 2010
    It is available in Part Store.com, click that link for price info.
    Thanks.
  • Sony Master
  • 4,924 Answers
If you only need tha cable ..than this is a solution ..but if you need the port itself to replace it in the camera ..I suggest to look for second hand parts cause it seams that it is not available on internet ..but I will keep looking ..
http://cgi.ebay.com/iLink-Firewire-Cable-6-4pin-f-Sony-HVR-HD1000U-HVR-A1U-/260470159934?pt=Camera_Cables_Cords&hash=item3ca53b3a3e
  • Catalin Turcu
    Catalin Turcu Aug 31, 2010
    by the way ..if you are talking about the port itself ...how do you got to this conclusion ..that it needs replace ...Im not sure that this part is something damageable ..maybe if you tried it into your computer and didnt work is just the lack of port driver into the computer or the Ieee 1394 is not enabled into the camera or the computer ..it can be many other issues..cause the port itself is nothing but a connector ..and usually the damage will occur on the board at the bus itself and not the port ..
    Do you know where I can obtain a HP-150 BOARD, COMPLETE?
How do I connect a field monitor?
Hi David,
I found a manual but not for your exact model....The link should show you possible ways to connect your cam to the monitor
Sony HVR S270U Operating Manual Connecting Monitor Or Tv
Hope this gives you some direction.
Thanks, and please rate if helpful!
Gary
Apr 07, 2016 | Sony Hvr-a1u 1/3" Professional Hdv...
How to fix Sony HVR-HD1000U camcorder if it is not charging
hi,
the fault should be in side the cam, start test from the charger connecting socket, measure the power in the mother board, if any of the fusible resistor or the regulator SMD found faulty, must replace.
Dec 01, 2015 | Sony HVR-HD1000U Camcorder
Why is my sony hvr hd camcoder not switching on
hi,
Tape door on my sony HVR-HD1000 will not go down
hi,
the tape deck mechanism is faulty, the remedy is to change the mechanism. if you can repair it open take out the mechanism, remove the head, eject housing,and the sensors mechanism locking plate etc, then peel out the flexible cable from the mechanism, and change it.
Nov 18, 2015 | Sony HVR-HD1000U Camcorder
HVR-HD1000E, The tape is locked-check the tab
hello, i think the tape tab is jammed if you will need help to: Disassembly,Repair, Maintenance or adjustments and more you can download the factory service manual from the below link:
http://goo.gl/ubSnD
Good Luck
May 01, 2013 | Sony HVR-HD1000U Camcorder
Cannot shut the cassette chamber of my HVR A1E Camera. Shows C32:11. Have already tried a lot of internet tipps, but without success. What ca I do
Dear
need not try any tips, as its the problem of mechanical deck, which is giving this problem it needs to get replaced, as the cable on the back of hvr-a1, mecha deck gets broken....
due tow hich the error starts coming...
get that replaced
Jan 30, 2011 | Sony HVR-A1E HDV Digital Camcorder
I have a sony hvr-hd1000u - I am getting an error message that says reinsert the cassette. Please let me know what you think the issue is. My camera will not work now because of this message. The cassette...
Hello.
This problem is solved by replacing the cassette complet mechanism, part number A1437006A MD (N220) SUB ASSY (S) A
... the cause: the flex is broken.
you can buy it on this website: https://www.servicesplus.sel.sony.com/sony-part-number-A1437006A.aspx
Hollmann.
serviciotecnico@videosistemas.com
Nov 27, 2010 | Sony HVR-HD1000U Camcorder
HVR-Z1E Capture problem
Hi George, Sounds like you and I are of the same level with this Cam and editing , would love to compare notes with you if you would care to drop me a line gemfilmsni@yahoo.co.uk
Pat
Jun 06, 2009 | Sony HVR-Z1 Mini DV Digital Camcorder
Video Cameras Logo
505 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
