Question about GE 24 in. GSD5110 Built-in Dishwasher
Dishwasher does not drain properly
  • 172 Answers
Check the drain hose and sink drains for obstructions. Check your disposal make sure it is clear if you have one. If drain lines are clear, then you may have an obstructioin in your pump. clear obstruction and it should work properly. If no obstructions are found check voltage going to pump during pump out. If you have voltage to the pump and the water is not pumping out, you will need a new pump. Good luck and I hope this helps you.
Mike Anderson
Posted on May 08, 2008
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Dishwaher does not drain cmpletely ?
Hello friend, thanks for your post!
I see you are having difficulty with your Frigidaire dishwasher not draining. Check the filter at the bottom of the dishwasher because if that gets clogged then it will not allow your dishwasher to drain properly. Additionally, check to assure that the sump pump is hooked up correctly to allow proper siphoning of your dishwasher. If that is correct it could be a potential problem with your control panel or drain pump and I would recommend consulting with a professional technician for proper diagnosis and repair. I hope this helps to some degree. -Matt
Sep 25, 2014 | Frigidaire Dishwashers
Dishwasher isn't draining properly
check your piston and nut assembly has to have air tight seal to drain properly should be free moving if not replace it about $15 online
Dec 03, 2013 | Electrolux EWDW6505GS Fully Integrated...
Dishwasher will not drain
Hello, Following things should be checked properly to see what actually the matter is.
1)Drain Hose It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again. 2)Pump Assembly The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective. Belt It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it. 3)Timer A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor. 4)Motor The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor. 5)Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them. Thanks
Jun 17, 2011 | Maytag Dishwashers
Dishwasher won't drain properly. Dishes aren't properly cleaned
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Oct 25, 2010 | Jenn-Air 24 in. JDB2150AWP Built-in...
My dishwasher is draining properly.
yes there is cleaners.Check filters at bottom of machine fiirst,then buy an cleaner.adrian,,,,
Jul 15, 2010 | Whirlpool 24 in. DP940PWP Free-standing...
Not draining properly
Check for plugged drain hoses in your dishwasher, also make sure that the pump is working correctly
May 06, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
dishwasher_pump-repair-kit.jpg Pump Assembly
dishwasher_belt.jpg Belt
dishwasher_timer.jpg Timer
dishwasher_motor.jpg Motor
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
there are several possible causes for your trouble. begin by disconnecting the drain hose at both ends and checking to be sure it is not partially blocked. Then check the pump to be sure there is no chunk of glass or other debris partially blocking it.
Aug 30, 2009 | GE Nautilus 24" Built-in Dishwasher
Dish washer won't drain properly
either you have a blockage inside the drain hose at the attach point under the sink , or possibly somehting stuck in the drain pump itself, preventing proper drainage, the drain pump is acessible form underneath, usually mounted ti the right side of dishwasher, "unplug first HOT WIRES"
Jan 01, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
GE 24 in. GSD5110 Built-in Dishwasher Logo
136 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
