Question about Kodak EasyShare V603 Digital Camera
Cracked screen a long story, short i have 2 v603 cameras. he first was dropped5 minutes out of the box and bent the lens so it doesn't work. the second this last weekend we were at 6 flags and the screen cracked from one of the roller coaster rides. is it at all possible to swap the screens out or would it be cheaper to buy a new one?
  • 2,712 Answers
Best bet is to buy a new piece. Although swapping the screens is possible, it is quite complicated to dismantle and mount again, unless you have prior experience.
Take it to the shop and ask for a repair quote. If it is too high, then might as well buy a new one.
And this time, BE CAREFUL!!!
Posted on May 08, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
I dropped my FUJIFILM S1600 camera and now it doesn't work, is there hope to fix it?
If it was my camera I would put my money towards a new camera.
It is obvious the zoom mechanism/motor is damaged and maybe some other damaged components.
You could get a quote to repair the camera but most likely they would charge you for the quote unless you go ahead for the repair.
Sep 26, 2012 | FUJIFILM FinePix S1600 Digital Camera
How do i fix a cracked screen on a kodak easyshare m575,its cracked an when turned on the screen is black an the lens barely comes out.
This is one of those bad luck unfortunate solutions where I had our daughter do the same thing to our Sony. So I found out then that there was better to replace than try to have fixed. Even laptops if under warranty and you spill water into the keyboard the factory will not honor the warranty. So to make this story short I replaced the camera with a Sony Cyber-Shot 12.1 Megapixels. Also has High Definition Video 720P. Wish I had better news but our daughter cannot get the camera now and I keep hidden and inside a padded case! These cameras are like crystal and very easy to break and more expensive to repair. Thanks, Sea Breeze
Oct 13, 2011 | Kodak EasyShare M575 Digital Camera
I have a kodak v603 when i try and turn it on i have a red light that flashes under the camara icon on the top left next to the screen. the camara dosent seem to work at all. can any one please help thanks
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 01, 2010 | Kodak EasyShare V603 Digital Camera
Lens jammed on a kodak v1253
I fixed my v1253 following these steps:
1. Pulled the battery when the lens starts to come out before it could power itself off.
2. Gently pull the telescope out until it clicks.
3. Use a fine tip paint brush to clear debris out of the cracks.
Camera works just fine now.
Jan 30, 2009 | Kodak EASYSHARE V1253 Digital Camera
Seems the lens mechanism is stuck and would need to be taken apart, its best to send the camera in for repair. <- Get a free estimate from there.
Aug 29, 2008 | Kodak EasyShare V603 Digital Camera
Camera V603
the camera should be brought to a repair shop since it might be a mechanical problem or parts may need to be replaced already.
Aug 25, 2008 | Kodak EasyShare V603 Digital Camera
Error E45
Turn your camera on and smack the camera against your hand. The E45 error means your lens is stuck. The lens on my V603 was stuck open, when I smacked it against my hand it closed and now works fine. Give that a shot.
Jun 23, 2008 | Kodak EasyShare V603 Digital Camera
Broken LCD- can't find part
Sometimes you can find used V603 camera's on ebay pretty cheap.
Jun 04, 2008 | Kodak EasyShare V603 Digital Camera
Cracked Camera
No easy fix. Pressure or impact is the usual cause of a cracked LCD. Try not to get the black stuff on's pretty toxic! The screen needs to be replaced (assuming there's no other, internal damage). They are usually in the range of $75 US.
Feb 19, 2008 | Nikon COOLPIX S200 Digital Camera
Kodak EasyShare v803 Is Frozen And Will Not Shut Off Or Retract Lens
same model as mine. Next to the memory card slot m rectangular black box.. battery pack. press it and it comes out , put it back and hold the on switch... presto!
Jan 01, 2008 | Kodak EasyShare V603 Digital Camera
Kodak EasyShare V603 Digital Camera Logo
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
