Question about Dryers
Can't find heating element in stackable washer/dryer
  • Anonymous Jul 08, 2008
    where to get parts
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    On a stacked model, it's located behind the dryer drum. Could you post brand name and model number?
My dryer Model GLER642A53 says it has fuses to replace if drum is turning but no heat but I can't find any fuses; could you tell me if this model doesn't have them or if it does then where; Please;
Posted on Dec 09, 2008
  • 172 Answers
The heater is located behind the tub in the dryer. Remove the control, then the front of the dryer. Then you will see the heater. If you want to see a picture or diagram go to and click on parts enter your model # in the model search and you will get a list of pictures and parts lists. If you would like to send me your model I can email you the pictures. This is a large repair to undertake for the average person. I wish you luck. Mike Anderson
Posted on May 08, 2008
Kenmore stackable washer/dryer. Model 417.93802209. Dryer will run but won't heat. Flipped breaker. Suggestions?
Possible that the heating element has burnt out, or that the thermostat that controls the element is defective. If you have a low or warm setting try that also as it may use a different element? Good luck.
Jan 20, 2013 | Washing Machines
Fridgidaire high capacity stackable FEX831CSO/ washer/dryer no heat
If dryer tumbles but won't dry usually means the heating element has broke in two. It can also be a thermostat usually installed near outlet of blower assembly or a limit switch installed in element heater assembly.
Jun 16, 2012 | Washing Machines
How do i replace the heating element on my kenmore stackable washer dryer 98702 machine
Could you please post the model number of the unit? It will be under the washer lid, in the dryer door, on the top, or the side of your unit.
Dec 25, 2010 | Kenmore Washing Machines
I have a stackable washer/dryer whirlpool model #WET3300SQ1. Heating element in dryer is not heating. We have replaced the heating element and it is still not working.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Aug 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Stackable washer dryer. Dryer is not heating up. I need to find how to replace the element
The element is behind the drum. You have to remove the front panal and pull the drum out.
Jun 10, 2009 | Kenmore Dryers
No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Apr 16, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
281 people viewed this question
Top Dryers Experts
