Question about Hawking AR740 ADSL Router with Modem
Hawking AR740 What I meant is that the only way I can communicate with the router is to telnet into it except it will not let me enter a password because when I try to type a password nothing is physically typed. I can not communicate with the router by using my web brouser which is IE7.
  • Rontut May 15, 2008
    Hey, where did you go? Did you give up on me? I tried everything you have suggested so far and they don't help. So much for you and Fixya.
  • 77 Answers
I see. I'm not really familiar on how to configure it. As far as what I've checked at its datasheet, it didn't mention that you can use IE to configure it. Have you been to its web ui before? What did you use to access it?
Posted on May 08, 2008
  • HAAi
    HAAi May 09, 2008
    Hi!
    I was browsing thru other sites and possible usernames/ passwords combinations for the Hawking routers are:
    username: (blank)
    password: (blank)
    username: admin
    password: (blank)
    Please try that if you can.
I want to change the settings of my Hawking router WR-258. I don't have a user name and password so I pushed the reset button. But the user 'admin' with no password is not correct. What is the default??
When the Login pop-up for the Router
appears, please enter “admin” for the
username to access the configuration screen.
(Note: By default, there is no password. If
you cannot get in, please reset the router by
pressing the button next to the antenna on the
back of the router and try logging in again.)
Copy pasted from the manual.
Jul 29, 2010 | Hawking Computers & Internet
I have a 2wire HG-B modem/router and I want to extend my wireless network by using a Hawking HWRN1A router. How do I configure my 2wire with my Hawking router, so it can work?
this hint is only possible if your hawking can be used a an access poit. if yes then try try the following:
connect you adsl line into your modem/router,
connect the lan cable of your modem into a switch
connect both your PC and Hawking into the switch
have your modem/router provide DHCP and DNS
configure your PC to gte its ip address and DNS dynamically
configure your hawking access point to also get its dns and dhcp dynamically (do this by getting into the hawking http page configuration, or telnet if you are good with commands)
now set a wireless lan with WPA or higher through your hawking.
there you have it.
doubts??? i have more solutions
Mar 23, 2009 | 2wire Computers & Internet
Hawking AR740
Hi!
Is that the router's login screen that you're talking about? Did you set a password at the AR740 before? Try possible passwords that you'd commonly using.
Try this link & hopefully this will help you..
http://www.hawkingtech.com/support/details.php?CatID=33&FamID=79&ProdID=101
May 08, 2008 | Hawking AR740 ADSL Router with Modem
Additional question
If there's a reset button then I would advise you to reset it.
You can also download the data sheet before doing the reset:
http://www.hawkingtech.com/support/details.php?CatID=33&FamID=79&ProdID=101#Datasheets
and according to the data sheet, your device came with a setup cd. Try to re-run the cd if you still have it.
May 06, 2008 | Hawking AR740 ADSL Router with Modem
The router is not communicating with my pc
Hi there!
The limited or no connectivity problem is commonly caused by some of these factors:
1. router not giving out an IP address (no DHCP)
2. Incorrect network key or passphrase if you enabled wireless security
I want to help you out and I need to ask you these:
1. How many computers do you have?
2. Do you have a wired or wireless computer?
3. Is it laptop or desktop?
May 04, 2008 | Hawking AR740 ADSL Router with Modem
Reset a password for IBM NWAYS Router 2210 Model 12E
Does this mean anything to you Remote Login Names and Passwords During a remote login, the device prompts you for a login name and password. You can display the login name when logged in to the device from a remote console by using a device status command. Logging in Remotely or Locally Logging in to a local console is the same as logging in to a remote console except that you must connect to the device by starting Telnet on your host system. To log in remotely, begin at step 1. To log in locally, begin at step 3. To log in from a remote console: 1. Connect to the device by starting Telnet on your host system. Your host system is the system to which remote terminals are connected. 2. Supply the device?s name or Internet Protocol (IP) address. To use device names, your network must have a name server. Issue either the device name or the IP address as shown in the following example: % telnet brandenburg or % telnet 128.185.132.43 At this point, it makes no difference whether you have logged in remotely or locally. 3. If you are prompted, enter your login name and password. login: Password: It is possible that there is a login and no password. The password controls access to the device. If a password has not been set, press the Enter key at the Password: prompt. Logins are not set automatically. For security, you can set up user names and passwords using the add user command in the CONFIG process. For additional information, see the add user configuration command, on 56. Remember to reload or restart to activate any changes. Note: If you do not enter a login name and valid password within 1 minute of the initial prompt, or if you enter an incorrect password three times in succession, the device drops the Telnet connection. 4. Press the Enter key to display the asterisk (*) prompt. You may have to press the Enter key more than once or press Ctrl-P to obtain the * prompt. Once at this level, you can begin to enter commands from the keyboard. Press the Backspace key to delete the last character typed in on the command line. Press the Delete key or Ctrl-U to delete the whole command line entry so that you can reenter a command. See ?Command Completion? on page 20 and ?Command History? on page 23 for more information. You can also use local Telnet commands on your Telnet client to close the Telnet connection.
Jan 21, 2007 | IBM NWAYS Router 2210 Model 12E
Finding the Dynamic Address Assigned by the ISP on a RT311 or RT314 Router
Here are three ways to find this information: 1. Within the browser interface of the Router, enter Maintenance and the WAN PORT is your dynamic address assigned by your ISP. 2. Enter the telnet interface (start-run-telnet 192.168.0.1-and enter password when prompted) of your Router and enter menu 24.1 (System Maintenance-Status) and the dynamic address is listed as the WAN IP address. 3. Enter the Serial Manager (except the RP114) of the Router and enter menu 24.1 (System Maintenance-Status) and the dynamic address is listed as the WAN IP address.
Feb 19, 2006 | NetGear (RP114NA) Router
Feb 19, 2006 | NetGear RT311 Router
Feb 19, 2006 | NetGear RP114 Router
Hawking AR740 ADSL Router with Modem Logo
Top Hawking Computers & Internet Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
