Question about Linksys WRT54G2 Wireless Router
When I try to connect my iphone says password incorrect. not sure if the settings are right or not
  • 550 Answers
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
Click Here for step by step instructions
Posted on Aug 31, 2010
How do I get my iPhone to recognize my new Linksys router.
passwords are case sensitive, so the problem is possibly just that you have capitals in the password and these are not specifies when entering the password into the iPhone
Jan 28, 2016 | Apple iPhone 5
Just got iphone back it says its diabled but for 23,685,670 minutes?
How to fix it if your iPhone is disabled?
If your iPhone is disabled and has to be connected to iTunes, you can connect it to an authorized computer, and the Enter Passcode window will show again. If you insert the right passcode this time, your iPhone will be all right again.
If you forget the passcode completely, I'm afraid that the only way to make it back to work is to reinstall.
Note, that the iPhone will erase itself after ten incorrect password attempts in a row. You can turn this off under Settings > General > Passcode Lock.
6 attempts: 1 minute
7 attempts: 5 minutes
8 attempts: 15 minutes
9 attempts: 1 hour
10 attempts: Erase data. If that option is off it will require connecting to iTunes to unlock.
Mar 04, 2015 | Apple iPhone 4S
WHY DOESN'T MY PASSWORD ON MY COMCAST ROUTER ALLOW ME TO CONNECT MY IPHONE TO WIFI?
Try this ....when you scan via iphone for your wifi instead of inputting password...go to the right chevron ....click forget this network.....then rescan wifi....then rein put password....it should accept.if not password for router has been changed....this means you need to go to routers ip (google it) at wwww.mywifirouterlogin.net. And input the user:pass assigned for that make model.then you will see the routers assigned password as it may not be the network key that is on the back or bottom of router housing.
Feb 01, 2015 | Apple Iphone 4s I Phone 4 S Factory...
Guest access cisco connect
If you give your password out indiscriminately, someone could get into your router and change the configuration (password). Not sure if this pertains to your router. Try to configure the router again and close down guest access until you can get a handle on who you can trust.
Dec 19, 2013 | Computers & Internet
Iphone can't see my printer
Make sure printer wifi is turned on. If it's on, make sure the settings are correct. HP printers have an issue with wifi. Try turnng it off and then back on. The wifi I mean. Also check the wireless security settings on the printer. It may be set incorrectly. This is assuming your trying to connect wirelessly.
Apr 14, 2012 | HP Office Equipment & Supplies
Can't connect iphone to dlink router
When my ipod tries to connect to my computer wirelessly, it asks for the password. I enter it, but it won't accept password. It finds the router ok, just says password is incorrect. I've checked and it's the right one. Any suggestions?
Nov 27, 2011 | D-Link DIR-615 Wireless Router
Unexpectedly, my voicemail has a password. I have no idea how that happened but I can't check my voicemail without a password. Not available in "settings" to change anything it remove this...
Hi, you'll need to restore your iphone as a new iphone it will wipe all the data from your phone but its necessary as if you try to restore your phone and use previous back ups it will bring the voicemail password back...Hope this helps..
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new...
Dec 26, 2010 | Apple iPhone 3G
I cannot send mail from my iphone 4...it keeps saying the user name or password for MSN is incorrect. They are not incorrect so what can I do correct this?
1- Delete the email account from your phone and re-enter it.
2- Passwords are normally case-sensitive, make sure you are using the correct characters.
3- Log into your email account from a computer and confirm your password is correct and works.
Change your password at your computer, log in and make sure the new password works, then start with step 1 above.
Nov 02, 2010 | Apple iPhone Smartphone
Flashing wifi symbol on netgear wireless router. iphone help
Hi
I will try to help you out with this....
Might be you tried to cinnect with the network many time thats why its keep on disconnecting,
you can delecte all the netwoks that you have in you 3G Iphone and try to connect fresh, if its still give you the same error then you need to change the channel on the router if still it wont connect I suggest you to change tehw ireless settings on you router and reconnect all the computer and you Iphone again with the new network...
Steps are below before you change any settings on teh router i would like to inform you that you will loss your wireless connection till you reconfigure and reconnect you computer with the new network again........
open the internet explorer on your wired computer
type in 192.168.1.1or you can type http://routerlogin.com
, it will prompt you for user name and password, the user name will be 'admin' and password will be 'password', make sure you type it in small case
click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I hope above mention will resolve your concern.....
Thanks
Harmeet :)
Sep 27, 2009 | NetGear RangeMax WPN824 Router
Cannot set up yahoo mail on iphone 3G
1. should go to http://mobile.yahoo.com/ to register by adding you phone no., you will receive sms and click link in the sms. 2. in iphone, add account manually then can set the pop = pop.mail.yahoo.com, smtp = smtp.mail.yahoo.com
Jul 09, 2009 | Yahoo Mail
Linksys WRT54G2 Wireless Router Logo
137 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
