Question about Kenmore 54501 Dehumidifier
Looking for the drain hose for a sears kenmore dehumidifier part 9181
SOURCE: Dehumidifier Kenmore 580.54501
Go to a Sears Authorized store and you can buy one there.
Posted on Jun 16, 2007
  • 184 Answers
SOURCE: Connector hose inside dehumidifier leaks
let me know if you still have this
Posted on Dec 19, 2007
SOURCE: Kenmore 54501 Dehumidifier
Clean the hose (it's full of black gunk)
Posted on Aug 12, 2008
  • 75 Answers
SOURCE: how to install suct tube and conncre hose
Go to; www.managemyhome.com.
When at that home page, place your cursor over, but do not click yet, 'Home Manager' in the red bar at top of the page.
There you will see five choices, click on 'Owners Manual'
Then find 'Kenmore' under 'Search Manuals By Popular Brand' and click on 'Kenmore'.
Then under 'Narrow your Results', scroll down to 'Dehumidifier' and click on 'Dehumidifier'.
Then you will see a five (5) page list of Kenmore Dehumidifiers along with the model Number.
YOUR Kenmore model # 58054501400 will be found on PAGE#2.
Click on page #2 and scroll down to the bottom of that page and find yours.
Then look at the right hand side of that page and see 'View Manual'
Click on 'View Manual' and there you will have it and the answers to any questions you have.
Good luck. :)
Posted on May 15, 2009
TampaNative
  • 778 Answers
SOURCE: Change my dehumidifier from draining by hose, to reservoir
I don't have the exact dehumidifier as yours, but on mine it's as simple as removing the hose, then the water fills the reservoir. Does it look like yours will do the same? If so, the hose fitting is also a sensor that will shut the unit off when it is full to avoid leaking onto the floor.
Posted on Sep 11, 2009
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
Drain hose connector
Check with a local Sears store. They specialise in Kenmore appliances and can maybe order one for you.
Sep 29, 2013 | Kenmore 54501 Dehumidifier
Kenmore 407 50 pint dehumidifier won't drain through hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Oct 13, 2012 | Kenmore 90701 70 Pint Dehumidifier With...
I have Kenmore dehumidifier 580.54701 70. Connected to external drain. Showing 01 code in humidity setting screen. Will not run. Approximately one year old.
Your model Kenmore Dehumidifier, I believe was was made my Haier, for Sears under the Kenmore name. In which case "01" indicates a circuit failure shutdown and needs to be repaired by an authorized Sears service technician. As it may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Kenmore 54701 Dehumidifier
Do I need an attachment to connect hose to my new dehumidifier?
it should be generic. you just need a part with the same thread pattern. you could fix that a lot of different ways. as long as it screws in your ok. make sure you put some teflon tape on it to prevent it from dripping
Oct 06, 2009 | Kenmore 54501 Dehumidifier
I have a Kenmore 54501 dehumidifier
hi,
somewhere there is a "knockout" or "plug" or something similar you have to remove or replace it to get it to drain through the hose, there should be some documentation in the owners manual about it, try troubleshooting in the back of the manual. If not look directly into the hose outlet and see if theres a plastic plug there, if there is use a screwdriver or something similar to GENTLY remove the plug, you may have to just study the machine when its running to get a better idea of how the water drains, maybe the machine came with something like it in one of the plastic bags the accessories came in.
good luck
J
Jul 23, 2008 | Kenmore 54501 Dehumidifier
Jun 30, 2008 | Kenmore 54501 Dehumidifier
hose connector is Sears part # 5214A20027A
dehumidifer is Model # 58054501300 or 58054501400
use these numbers on searspartsdirect.com
Jun 11, 2007 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Logo
55 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
