Question about Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
Need to know belt size fo the stihl ts400 concrete cutoff saw
    Novelist:
  • 111 Answers
You should go to a Stihl dealer and ask for the belt for a TS 400 Cut Off Saw. The belt is ribbed, you should only put on a Stihl part to replace the belt and make sure the belt is under the correct tension. When you go to the Stihl dealer you can ask them to show you how to make sure the belt is under the correct amount of tension.
Posted on Mar 30, 2011
No fuel to spark plug stihl ts400
could be fuel pipe bent/hole in fuel pipe or yes could be carb
May 20, 2014 | Stihl Concrete Cutoff Chop Saw Clutch...
Ts400 hard starting
Check the fuel tank vent, it could be creating a vapour lock in the fuel tank
Nov 05, 2013 | Stihl Concrete Cutoff Chop Saw Clutch...
Looking for a short curcuit wire
If you are referring to the wire that kills the engine it will be attached to the coil at one end and the on/off/choke lever/switch at the other end. If you need to replace it then contact a Stihl dealer.
Aug 13, 2012 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl Demo saw 400 pulls with no compression
From snor38@gmail.com Hi kaqibso these saws are equipt with a decompression switch.It is located on the right side of the unit and has a red cap on it, pull out on it. Best of Luck......
May 30, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
I have a stihl st400 disc cutter & I think the pull start needs cleaning, any advice?
compressed air works well. you really need a gun with a long skinny nozzle. for example
Jan 26, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Wiring diagram for a stihl saw ST400
There is no diagram. it is a simple system the coil for the plug has a kill wire that runs up to the thumb switch.
page 31 of the service manual shows the connectors.
Make sure the wires are not rubbed through.
I am a Gold certified Tech for Stihl. Feel free to ask any other questions you might have.
Jose
link to ts400 manual
Jan 12, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Does the TS400 need engine oil apart from 2 stroke mixture
Hello. No, the oil mix is designed to do all that is necessary. Stihl 50:1 two stroke engine oil or equivalent is recommended for proper operation, cheap oil does not have the additives needed too keep rings free and inhibit carbon build-up. Also do not use BIA or TCW rated oils, or any others with duel purpose ratings.
Thank you
Aug 22, 2010 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter Logo
451 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
Spud Howell
ray gallant
Are you a Stihl Saw Expert? Answer questions, earn points and help others
