Question about GE Profile TPX24PBDCC Side by Side Refrigerator
I have a GE profile TPX24BRYF BB model. At the water inlet valve, there are two tube connections. Which side gets connected to the tube on the outside and runs to the top of the freezer, the left or right side? The right side is blue and the left side is red on the valve if that helps. The other tube runs under the refrigerator. Thanks
  • 1073 Answers
SOURCE: GE Profile French Door bottom
IT IS STILL UNDER WARRANTY call ge at 800-386-1215 for factory service
Posted on Apr 15, 2008
mikedurland
  • 481 Answers
SOURCE: ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Posted on Jul 05, 2008
  • 4 Answers
SOURCE: Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Posted on Jul 15, 2008
SOURCE: GE Stainless Steel Profile refrigerator/freezer
the drive gear is stripped that actuates the custom cool damper doors. You will have to replace the damper assembly.
Posted on Feb 04, 2009
  • 16 Answers
SOURCE: GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
Posted on Jun 10, 2009
I have a GE profile model # TFX30PR the plastic tube for the icemaker keeps freezing
The water inlet valve is bad allowing the water to drip into the tube and allowing it to freeze there clogging the tube. This is the most common cause for the tube to freeze. You will need to replace the "water inlet valve" on the back of your unit. Here is the part you need to order.
Oct 28, 2012 | GE Profile Performance 29.8 cu. ft....
I do not believe the other advisor understand my problem. I have a GE Profile Arctica refrigerator PSS25NGMDBB. The problem is the cup fill (GE part name) is frozen and full of ice. So when the ice...
You are right. The water inlet valve is leaking a small drip and it freezes when it reaches the cold air in the freezer at the fill tube. Melt the ice in the tube with a hairdryer and replace the water inlet valve. It's on the back where the water supply connects to the back.
Feb 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
There are three hookups in back of refrigerator. Do I need to run 3 differen tlines of water supply?
To the best of my knowledge there is only ONE source connection and 2 internal connections that would connect to the water inlet valve assembly. This almost sounds like someone removed the inlet water valve and left it off of the unit. (Or.. the water valve was never connected at all)
The plastic tubing just presses into each of the water inlet water valve holes. you have a 50/50 chance of getting the connections correct if they are not labeled. If it is connected incorrectly when you depress water dispense the ice maker will over fill with water. (Swap the connections)
The inlet water valve will look just like this one. It will have 2 inside connections and one external connection. (see link) http://www.fixya.com/uploads/images/1E1A1B9.jpg
There should also be Two black and flat 2 pin electrical connectors dangling if the water valve was removed.
Take a look and let me know if your water valve is missing.
Thanks for choosing FixYa.
Kelly
Dec 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
The electricity went off yesterday while we were gone (not sure how long) and the freezer is no longer staying cold. The ice maker hasn't made any ice and it has melted on top of the other food. We have a...
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
GE Profile Arctica refrigerator - water is leaking from the bottom of the solenoid where the plastic hose goes up to the water filter (on the outside of the refrigerator.
Turn off the water supply and check for cracked or broken water tubing/line. Make certain that there is teflon (white) tape on threads connecting water inlet hose from shut off valve at wall to water valve at refrigerator. If there is no apparent damage to tubing or hose, then your problem may be with a water valve solenoid that is not seating/closing tightly. Replace the water valve assembly, if necessary.
Note: If plastic tubing is damaged, etc., you can splice the tubing with a "coupler" and/or more tubing purchased from Home Depot or Lowe's.
Feb 19, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile refrigerator side by side, water and ice through door. Ice maker works fine, water will not shut off. Had to turn water to frig off.
The water inlet valve on the back where the water supply connects to the unit is stuck open. You may can clean the valve out and get it to closing or just replace it.
Dec 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
We have a ge side by side refrigerator...while moving it we broke something off the back...it was like a little tube or coil...it was really short..maybe 4 inches...i think it led to the icemaker...i dont...
Possibly the water inlet valve? Look at the water line on the back that goes up the back to the ice maker. The bottom end should be connected to the water inlet valve. This is also where the water supply from the house connects.
Oct 02, 2009 | GE Profile PSI23NCR Side by Side...
GE TFH27PRSA ice maker water fill tube and receving bucket on ice maker keeps freezing closed. No other problem with unit including water despenser to door. Once the tube freezes closed, water is leaking...
all is normal with the defrost heater getting red hot.
as far as the inlet tube freezing, you most likely need a new water inlet valve. it may not be closing all the way and water is slowly dripping into the icemaker and freezing up right away. a new valve should fix your issue. here is the part that you need. http://www.repairclinic.com/SSPartDetail.aspx?s=t-TFH27PRSA-%3d%3di1032629&PartID=1032629
Aug 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
GE Profile TPX24PBDCC Side by Side Refrigerator Logo
238 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
