Question about Maytag MSD2756G Side by Side Refrigerator
My Maytag refridgerator wall between freeze and refrigerator is warm (especially middle portion) Is this normal? At back I have cleaned our dust and lint from condensor coil (lots of lint). My fan is working fine , too. And I still get that warm on that wall. Is this ok?
  • Maytag Master
  • 43,501 Answers
That warm is okay...
it is intentional to keep condensation from forming...
now if it gets hot then there are other problems...
heatman101
Posted on Aug 31, 2010
253.63712300 sears Hoffman estate fridge has small pools off water that sometimes freeze on back of fridge shelf. Sometimes small trickle of water leaks onto floor. the refridgerator and freezer are s
probably dust, hair, lint plugging the drains.
you have pets?
have it serviced by a professional, or you can disassemble all the drain lines and conduit and pans and clean yourself. good luck
call a PROFESSIONAL
Dec 29, 2014 | Estate Refrigerators
I have a frigidaire side by side refridgerator / freezer. Currently my freezer is about 34 to 40 degrees. The dividing wall between the ref. and freezer is warm to hot depending on when you check it. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | Frigidaire FRS26H5AS Side by Side...
My refridgerator is running but the freezer isn't freezing and the refrigerator isn't cooling. Where do I start?
First thing is to clean the coils or grill under (or in back) of the fridge. This transfers the heat from the refrigeration unit to allow the coolant to dissipate collected or accumulated heat. If the coils are clogged with dust or other debris, it will hamper this process and waste energy.
Unplug the refrigerator.
Pull the fridge out from the wall, remove the back protective cover and vacuum everything you see. The coils may be on the bottom and you may need to get creative to clean it, but it will be worth it.
Good luck. don't forget to vote.
Oct 10, 2010 | Magic Chef CTB1821AR Top Freezer...
My Maytag regridgerator wall between freeze and refrigerator is warm (especially middle portion) Is this normal? At back I have cleaned our dust and lint form condensor coil (lots of lint). My fan is...
This is a sure sign of pending compressor failure (high heat and head pressure, Since that 2 in section comes directly from the compressor.For verification,
Remove the back cover, and place your hand on the compressor.(careful,may be hot) should be able to leave your hand on compressor without burning.
Check condensor fan in that same area , It may be not running
causing all the trouble
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 31, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refridgerator
Hi. thanks for the question. the heat between the doors is normal . to solve . pull the fridge away from wall .remove back panel. clean all lint in coils .Dust in the coils causes the heat between the doors to get warmer . so cleaning of coils. will solve the problem thanks the appliance doc
Oct 04, 2008 | Jenn-Air JCD2389G Side by Side...
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Refrigerator side of my side by side to warm
Check the back wall of the freezer section for signs of frost buildup. Your problem could be caused by a frozen evaporator coil in the freezer section. After making your check come back and give the model number of your Maytag .
Jul 03, 2008 | Maytag Refrigerators
Frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
61 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
