Question about Whirlpool LGB6300 Gas Dryer
My dryer will light at 1st but won't stay lit long. Will not light again after the initial lighting. I replaced the ignitor already
  • Whirlpool Master
  • 3,740 Answers
Hi Phillip. You are half way there by changing the ignitor. If a gas dryer burner lights and then rapidly goes out is it usually either a flame sensor. moisture sensor or high limit thermostat. I note you only get ONE light and it no longer lights.
Heater assembly or burner shuts off prematurely.
1. Improper or inadequate exhaust system.
1. Weather hood flapper maybe restricted.
1. See “Installation Instructions” for exhaust requirements.
Insufficient gas supply.
1. Verify gas shut-off valve is not partially open or closed.
1 Verify proper gas pressure is being supplied to unit.
(Dryer not properly equipped for type of gas
used.)
1 Verify gas type.
1 Refer to “Gas Burner Conversion Procedures”.
Improperly adjusted burner flame.
1 Properly adjust burner flame.
2. Limit thermostat cycling off. · Test limit thermostat and replace if failed.
3. Flame sensor contacts failed in closed position.
· Test flame sensor and replace if failed.
· Verify proper gas pressure is being supplied to unit.
4. Failed timer. · Test timer and replace if failed.
5. Failed electronic control. · Test electronic control and replace if failed.
6. Failed moisture sensing control. · Test moisture sensing control and replace if failed.
7. Broken, loose or incorrect wiring. · Refer to appropriate wiring diagram for correct wiring.
I still think we are dealing with a flame sensor, high limit thermostat or moisture sensor problem.
Things to check:
http://www.applianceaid.com/images/ldrm-gas-burner.jpg
Check 1 The moisture sensor is inside the dryer on the left side of the access. Make sure it is clean and that there are NO metal objects in around or near it. Some times things like straight pins.. paper clips.. staples.. bobby pins et all make their way on to and around moisture sensors.
After that check out the flame sensor on the side of the ducting:
http://www.applianceaid.com/images/radsnsr.gif
It should NOT read open. If it does or has a really high resistance it can be the culprit.
Then you will need to test the gas valve solenoids there are 2 different types. 3 pin and 2 pin http://applianceguru.com/dryers/gasdryervalveohms.gif
If found bad they are replaced as a set:
http://www.pcappliancerepair.com/part-detail.php?affiliate_id=AppAid&item=279834&brand=WPL
There is still the thermistor and or the high limit thermostat depending on model.
Thanks for choosing FixYa.
Kelly
Posted on Aug 31, 2010
Gas burner won't stay lit
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Dryers
Gas dryer won't heat up
Burner not lighting/staying lit. Most likely the ignitor.
Check out
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
Dec 09, 2009 | LG DLG5932W Gas Dryer
Have a Kenmore Gas Dryer 80 series, model # 110.78842990 that runs but has no heat, have torn everyting apart and cleaned out all the lint, but still no heat.
Check out
Dec 08, 2009 | Kenmore Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Gas dryer flame won't stay lit
Check for a blocked vent.
Mar 12, 2009 | Amana Dryers
Won't stay lit
You ignitor is working and sensor is working because it will fire up. so those pesky coils are intermittant because they get hot and quit cool off and work some more . replace them
cc8e664.jpgHere is a little ditty I wrote some time ago about this subject
INTERMITTANT COILS
Mar 07, 2009 | Maytag MDG6000 Dryer
Oven will not light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
iuop
Nov 19, 2008 | Whirlpool SB160PEE Gas Single Oven
Dryer won't dry clothes completely. stops heating.
Clean vent 1st. Electric? Gas? More information is needed for sure. Does it come on and light up (assuming gas) then never light up again? or....are you running it thru like 3 cycles to get them dry? You say it stops heating......how long until it starts again....i assume that if you turned it on the next day that it would heat up right? (at leat initially) Can you see the heating element(or ignitor and flame)?
Jul 27, 2008 | Dryers
Whirlpool LGB6300 Gas Dryer Logo
82 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
