Question about Kenmore Dryers
MY kenmore elite dryer model number 11063956102 will start when I push start but will not stay running.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
I have a kenmore elite gas dryer model # 70992990 <And when i push the start button and let off it wont stay running! Can you help?
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Sep 16, 2010 | Kenmore Dryers
Dryer won't stay running after pushing the button.
that isn't the model number,it will start with 110. or 417.send the full model number and i can look up your dryer,most likely it's the even heat board or the motor relay but without the model number i can't look it up for you,these parts are in the top console,call the parts store give them the model number and they'll give you the right part or send it to me,let me know what you find
Jul 20, 2010 | Kenmore 63942 Dryer
Have a kenmore elite quiet pak ll gas dryer start buton doesn't start. when release the button dryer stops
if the dryer runs when you push the botton in and stops when you stop pushing on the button you have a bad even heat board or a bad motor relay.these parts are located inside the top console,if you send me the model number i can look up your dryer and tell you the part you need to change out
Jul 02, 2010 | Kenmore Dryers
My Kenmore dryer "Start" button does not stay depressed.
a complete model # from inside the door would be helpful, on wost dryers when this occures the motor is packed with lint so the sentrifisle switch cant move from the pastion to the run or the switch on the motor itself is bad, the run windings in the motor could be bad. some of thethe more complicated dryers have a relay on their control board than burns out. try blowing out the motor with compressed air or the blow end of a shop vac use the skinney attat. to concentrate air
Dec 08, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
My Kenmore Elite Total Care System with Evenheat Dryer will not stay on. I set the drying time and when I push the start button, the dryer runs but shuts off as soon as I release the button. The start...
It sound`s to me based on your description, the start relay/switch is faulty. (the other unlikely possibility is the start switch in the motor).
If you call a local part`s supplier or check out searspartsdirect.com, apwagner, partsdepot, repairclinic etc. with your model & serial number, they should have that part for you.
Hope that help`s you. Please take a second and rate the information provided to you here at fixya.
Thanks for visiting fixya and good luck.
macmarkus :)
Dec 08, 2009 | Kenmore Dryers
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Kenmore elite dryer model #110.63952102 start button wont stay on everything else works
I have the same problem with my Kenmore Elite dryer (model#110.74992300), and I replaced both the motor and heater relay and the problem solved. You can get the relay from www.mouser.com for $3 each. The model for the relay is T9AP1D52-48. You may want to open up the dryer to verify the relay model, it is printed on the relay.
Sep 20, 2008 | Kenmore Elite 20972
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
91 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
