Question about Cameras
RCA ProV730 Video Camera manual how to change the time on the cam?
How do I set up my secura cam SW214-SCC
Step1: At the end of your SecurityCam cable you will find three colored plugs: Yellow(Video RCA), white(Audio RCA),Black/Orange(DC Power) or identify
OR
Identify the cables at the end of the SecurityCam cable as color for video ,audio and power may vary.
Step2: Plug Video RCA plug(1) into the "Video In" input(3)(Usually located at the back of your TV or VCR)
Step3: Plug the audio RCA plug(2) into the "Audio In" input(4)(Usually located at the back of your TV or VCR)
Step4: Connect DC power plug(5) at the end of your Security Cam into the end of the power adaptor(6)
Step5: Plug the power adaptor(7) into the main power point in your wall
Step:6 If you have AV/TV with RCA sockets you will need to switch the TV to the AV change to view the camera.
Pictures is attached. Please have a look at it.
Jul 17, 2016 | Office Equipment & Supplies
Rca cc4352
you will have to reset the camera or go into settings and find were to change it frome b/w to color
Jul 30, 2008 | RCA CC4352 Camcorder
How to hook up and turn on Hasbro Dance Cam (don't have instruction manual)
The Playskool Dance Cam requires 4 AA batteries and has RCA video connector (yellow) and RCA stereo connectors (red and white)
Plug these into the RCA connectors on the TV of the same color
You will likely need to change the AV (audio video) input on the TV to RCA
The extra 1/8" audio cable is so you can play your own audio by connecting to cd player, ipod, radio, etc. this is optional does not need to be connected.
That's all that is needed you should see it on the TV screen. Further basic instructions will show on screen.
Mar 05, 2011 | Playskool Dance Cam
When attempting to transfer to CD for long term preservation, lines in video are transferring. Can the heads be cleaned are other things to be considered during transfer from original 8mm take of Analog...
8mm head cleaning tape should be available at most electronic stores.
If the tape does not help after two or three attempts you are best to take it to a techincian.
BTW: The tape is one of the best backup mediums. Transferring to DVD is a great option for viewing only.
Feb 06, 2011 | RCA PROV730 8mm Analog Camcorder
How can i upload the video from my digital cam
most cameras have a mini dv connector slot someplace it will go mini dv connector to usb or rca or firewire, your pc must have a vidoe card that will accept the rca plug or a firewire or usb connector and then you usually need the camera software that allows computer to recognie the camera in TWAIN download selection.or video software that will recognize the input source(camera type).
Dec 28, 2009 | Sony Cameras
How can I hook this cam up to my Television?
For this camera you will need to find in your equipment (or purchase) a "stereo video cable "
This cord features a 1/8th (male) headset jack on one end and 3 male RCA jacks on the other. (yellow/red/white).
Plug the 1/8th jack into the camera's AV input and the RCA plugs into your TVs RCA port input and select the correct AV input (AV 1, 2, etc)on your tv selector and the camera should play through your tv.
Nov 04, 2009 | Canon ES75 Camcorder
Camcoder has no battery and no electric plug charger. Cant open it to put the casset in
Go to Radio Shack and buy AC-To-DC power adapter($18.99) and make sure to pick up the Adaptaplug "B" which is free. The power adapter has multiple settings, but this cam uses 6 volts.
I just picked these up for my old PROV730 that I'm repurposing as a baby monitor.
Oct 11, 2008 | RCA PROV730 8mm Analog Camcorder
Recording from a vcr
check a/v imput on camera settings, make shure that u have audio alsso conected, tried to use diferent output (DVD), make shure is playing .,
Feb 03, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Rear view camera setting???
Dear debbie,
This could be caused by the following:
Purple/white "reverse sensor wire" not connected to vehicles reverse lamp harness. (Are your reverse lamps functioning?)
OR
Reverse cam video out not connected to Kenwood's "rear view camera input" (Yellow RCA socket behind the unit).
The monitor set up controls merely switch R-cam betwen "full, just, zoom and normal" modes. No provision here to ebnable or disable the cam.
When you put your car in reverse dos the monitor screen change?.
Jango
Dec 11, 2007 | Kenwood DDX7019 6.95 in. Car Monitor
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
