Question about Global Go-Kart Ride-On Cars Battery Operated Yellow
Purchased a used Dingo a few weeks ago for my kids.Let them rip around a little bit on day, everything was great, including huge smiles. Went to use the next day, vehicle would not move forward. Clutch moves in & out.Thought belt was worn .Bought new belt. Still won't move. Chain drive moves forward & reverse but won't move while engine running 'clutch engaged.Any help ? 2 kids going back to school soon & want to end summer on a high note.
I have a year 2000 toro dingo (walk behind). The I have a year 2000 toro dingo (walk behind). The motor runs great but stalls out immediately when I engage the track. To move forward or back. I checke
One of your hydro pumps are seized. this is causing the engine to stall when ever the torque is transferred to the pump. There are the small pumps (or final drives) under the engine. One or both need to be replaced
Mar 27, 2013 | Toro 2007 Dingo Tx420 Walk Behind Mini...
Hello my girlfriend owns a 2002 Toyota echo 5 speed we bought it used she has put bout 4000kms on it since then. A few days ago now that its cold around -10 she started the car and the rubber gasket around...
If oil pressure is too high, check if the pressure relief valve is stuck or inoperable.Don't know where it's at on your toyota. Check with a garage or dealer for location. Other possibility is a clogged oil passage somewhere. For that, a good oil conditioner might help.
Dec 30, 2012 | Cars & Trucks
We purchased our DVD player about 3 mths ago and everything was fine, then about a week ago after the kids were watching TV and went to record a show the DVD turned itself off. Now when we turn on our DVD...
If you only purchased it 3 months ago it should still be under warranty.
Just bring it back to your place of purchase for a refund or exchange.
Apr 16, 2011 | Televison & Video
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Acer Aspire 7520 EVERYTHING IS HUGE
I'm suspecting a faulty driver. Try searching " (model number) Motherboard driver".
May 07, 2009 | Acer Aspire 7520-5185 Laptop
Freezes for 7 to 14 days then just quits!
hate to tell you but your compressor is going out on your freezer ,,, i'd look for another freezer.
Larry
Oct 28, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Refridgerator was never that cool now its warm
put a thermometer in the refrigerator and one in the freezer to see what it reads each day when you had the freezer open it it coses it to work harder like having an air conditioner on with the window open it has to work harder to keep it cold so by recording them temp to see if its dropping or it stays the same you might have to get it looked at but for just getting it a week ago it should not have hurt anything just leaving it open a little bit might just be normal for it to be hot i have a side by side and the side is hot but not to hot just warm. let me know hope that helps
Jun 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Global Go-Kart Ride-On Cars Battery Operated Yellow Logo
110 people viewed this question
Top Global Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Global Toy Expert? Answer questions, earn points and help others
