Goodman CK42-1C Need a new Capasitor. What size? 440 40/5 or 370?
    Guru:
  • 588 Answers
The rating should be on the capacitor, for instance 40/5-440 means you have a 40 microfarad capacitor for the compressor and a 5 mirofarad capacitor for the fan motor and it's rated for rated for 440 volts.
The capacitor should be whatever the compressor and fan calls for, but in a emergency you can use anything within + or - 10% on the microfarads but the voltage should be the same or higher than what's called for, until you can get the proper capacitor.
The higher the volts the better the insulation value of the capacitor, so you can always go to a higher voltage rating.
If you can't read the specs on the capacitor then look on the compressor and fan for the ratings. If they're not there then take the model number of the compressor and fan to the parts house and they can look it up for you.
Posted on Aug 31, 2010
What size run capacitor do i have to get for a mitsubishi muh12tn
Best thing to do would, is look at the one that is currently inside of it, and just find a local Ac supply house, and take the capasitor with you and purchase a new one, Normaly if you look at the numbers on your current capasitor it will have the number with a UF just to the right of the number.
Nov 05, 2013 | Mitsubishi MSH12TN Air Conditioner
My goodman cental air system is having problems. First, the blower inside (furnace) keeps running for hrs after the outside condensor shuts down. Now, the condenser blower motor wont operate at full speed....
the cause of your indoor fan running all the time or for long time after your heat pump has stopped heating is the fan delay relay. It has welded its internal contacts together. If you take off the side below the control panel, the fan delay relay is normally mounted on the header where the fan discharges. Good news, the fan delay relay are fairly inexpensive and easily to change.
As far as the condensing fan motor not running at full speed, when it was changed, did the technician install the correct fan motor. Most condensing fan motors are either 875 rpm or 1175 rpm. They are exactly the same size and if the technician did not look closely he could have installed the wrong rpm motor. There is another possibility, he may have used the wrong capacitor. I have seen the condensing fan actually operate backwards at a lower than normal rpm. The fan if properly installed will discharge air upwards.
Jul 17, 2012 | Goodman CLQ36AR49 Air Conditioner
I have a Goodman Manufacture furnace, model #GMPN120-5. The furnace keep clicking on /off while asking for heat. I even turned the fan to the on position (instead of auto) and the problem continues. ...
Can you tell me if the burners are lighting at all? I need a little more information about the cycle. If the burners are lighting and then going off immediately you need to clean the flame sensor. A small rod on the opposite end of the burners from the glow bar. Let me know if this is the situation, or describe the cycle completely and I will try to help.
Mar 19, 2011 | Goodman Heating & Cooling
Motor wont start but runs without the belt on
replace the new capasitor,the capasitor is placing near the motor,unplug the unit before remove it and be carefull to touch the pin of the capasitor coz of high voltage,check the micro farad of capasitor and buy a new one,,but sometime the motor also problem if the motor have water mark is means replace the motor of new one,but ask the price of new one if is expensive try to buy a new one with 1warranty compare the motor you buy is only 1month warranty.
Dec 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Air condition fan not working and inside the vent is not cooling
fan moter may be bad if it will not run it will cause the compressor to overheat and it will not cool also check the capasitor
Aug 12, 2010 | Goodman CKL42AR42 Air Conditioner
My air conditioner fan comes on for a second and goes off
check capasitor they are bad abot going out also check contacter it maybe loosing power
Aug 12, 2010 | Goodman CKL24AR24 Air Conditioner
Fan is spinning on compressor but air inside not cooling house
that means that it can be the capasitor for the compressor is faulty or it can be one of the windings in the compressor is burnt
Sep 26, 2009 | Goodman CLQ36AR49 Air Conditioner
Ac unit central
Sorry, we don't have water cois in our area.
Aug 07, 2008 | Goodman CLQ36AR49 Air Conditioner
GOODMAN ARUF3642
These guys list the actual sizes of a good selection of goodman filters - just measure the old one or the space where it should be and match it to the right filter(should be a fairly tight fit). http://www.filters-now.com/products/dgb.html#skipmenu and this site describes what the different filter types available are http://www.oxyclean.com/goodman.html Hope this helps :)
Mar 07, 2007 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
824 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
