Question about Astar LTV-32HBG 32 in. LCD Television
I can not turn on my astar LTV- 32HBG TV, power indicator light blinking.Before the blinking problem I had to unplug the tv then plug it back in to get it to turn on.I came home one day and the power indicator light is blinking,the unplug trick does not work any more.Some one on line said it could be the power trnsformer driver ic.Please tell me what you think and were I can buy the part so that i can fix it myself
I has the same problem. The power switch on the back of the set fried. I ended up removing/bypassing it completely by disconnecting the 2 wires on it that came from the power plug and soldering them in place of where the switch was soldered to on the board. Before you do this check to see if there's a burnt/melted plastic smell at the switch. After I opened my set I could see that it was melted.
Posted on Feb 15, 2011
My tv has no power at all
U check the power source like the power socket outlet?U tries tv unplug,replug the tv back like about hour later see if the tv resetting itself back to the factory setting and work again.Same result after this ur tv still have no power at all than the tv have a dead power supply board.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Aug 31, 2011 | Astar LTV-32HBG 32 in. LCD Television
Astar LTV-32HGB blinking power indicator light
this sounds like typical power supply problems. these units have a stand-by power thats always active;even when unit is off. this allows the settings to be remembered by the u-con. (microprocessor) when you unplug the unit it will reset to factory default, thus erasing faulty power-supply data from improper voltages.(usually low readings) swollen capacitors on power-pcb will effect operation. recommend replacement of all electrolytic caps on power board. even smd's (surface-mounted-devices) can be leaky. they can be checked in circuit with an ESR meter. this is an analog sweep meter (needle gauge, not digital) that can detect faulty, leaky capacitors.
Mar 09, 2009 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Blinking power indicator light
When TV indicator light is blinking and after that the power will cut off. First you need to check the power board. But I am still need more details of your tv. please call 323-767-6030 and I will go through thes trouble-shooting, with you.
Mar 08, 2009 | Astar LTV-32HBG 32 in. LCD Television
I have a Astar LTV-3001 and can't turn on. and I have other LTV-30MA This one have sound , no picture, can you please guive me sam help, I use to repair, Tvs. a time a go
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jan 03, 2009 | Astar LTV-3001 TV
I didn't get a manual when I purchased my TV
I have worked as an Electronics Tech in Astar before closing and I have collect all the model information, hope this is help.
At this point I only have the Astar model manual; 19bg, 2001, 20PW, 20SD, 26ASB, 27ASB, 32ASB, 26OB, 3001, 3201, 32BG, 32HBG, 37HBG, 42HBG.
I will update on the LTV-2701 by contact me at 323-767-6030
Dec 01, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Astar LTV-2701 27
Jun 01, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
M LTV-32HBG
We have a Model LTV-32BG that has power switch problems as well. The tv will turn off on it's own & you have to use the power switch on the back of the tv to get the green light on the front of the tv to "blink" again, or in otherwords be ready to turn on. Today in fact, the tv has turned off so much that I have given up on watching tv...
Apr 01, 2008 | Astar LTV-3201 32 in. LCD Television
Astar Power Supply
Fixing the internal power no problem depending the power board it's burn or not. second thing is your LTV-32HBG TV with one HDMI connection or two HDMI connection? I know more about these Astar TV because I have work for the Astar co as an electronic technician before and I only give out such information how to repair these tv. so, call 323-767-6030 and I will help you go through with you problem by the phone.
Mar 18, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Astar LTV-32HBG 32 in. LCD Television Logo
224 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
