Question about Cameras
Sony camera showing digital card error how can i fix it?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 31, 2010
My sony digital camera shows problem error E:61:00 how i will fix this problem
take out all cards,,and batteries,,look for a reset button somewhere,,,,also check sony online
Oct 24, 2010 | Sony Cyber-shot DSC-H10 Digital Camera
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
My Sony DSC-S75 camera shows a format error when I insert my 128MB memory stick also blinking is C:13:01. Any idea's how to fix? Thanks!
Format error display shows memory card is unstable and need to be format through format option in Camera menu.
Format memory card, if that does not fix the issue, try another memory card in camera and check this memory card in another camera just to make sure either camera got problem or memory card is bad.
Jan 01, 2010 | Sony Cyber-Shot DSC-S75 Digital Camera
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
File Error
Try using a separate card reader to download your pictures. Then, format the card in the camera to optimize it and completely erase it.
Sep 05, 2009 | Sony Cybershot DSC-S950 Digital Camera
Sony cybershot 7.2
When memory card got unstable, camera gives format error. Format memory card by format option in camera Menu.
Jun 18, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
My digi cam shows file error
Please format memory stick by going into camera menu and selecting format option there.
File error problem will be resolved.
Dec 13, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Memry card error Sony DSC-V1
Hopefully you've resolved this by now, but if you still have the corrupted card then I should be able to recover any files from it for you, reformat the card, and return the card and data back to you. I use EasyRecovery Professional which certainly wasn't cheap but has never failed me yet.
No charge, you just pay for postage both ways.
Feb 19, 2008 | Sony Cyber-Shot DSC-V1 Digital Camera
File error
I take a picture and go back to view it and file error shoews up. Can those phtos be retrieved?
Nov 23, 2006 | Sony Cyber-shot DSC-H2 Digital Camera
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
