Question about Maytag MSD2756G Side by Side Refrigerator
My Maytag regridgerator wall between freeze and refrigerator is warm (especially middle portion) Is this normal? At back I have cleaned our dust and lint form condensor coil (lots of lint). My fan is workeing fine , too. And I still get that warm on that wall. Is this ok?
    President:
  • 3,773 Answers
This is a sure sign of pending compressor failure (high heat and head pressure, Since that 2 in section comes directly from the compressor.For verification,
Remove the back cover, and place your hand on the compressor.(careful,may be hot) should be able to leave your hand on compressor without burning.
Check condensor fan in that same area , It may be not running
causing all the trouble
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 31, 2010
Automatic defrost refrigerator not cold enough
manually defrost unit. no hot water... clean out drain hole with thin wire with a small cloth tied to end (very small amount ) dipped in clorine bleach. blow out if wire not available. clean around fan housing clearing any dust particles...plug in and check temp.all should be fine....manual defrost/clean drain, wash out interior with bicarb every 6 months.hope this sort it out ....
Feb 09, 2010 | Refrigerators
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
What to do next--the freezer hasn't been sealed for a day
unit might need cleaning under and in back of fridge (dust bunnies) use vacuum. front bottom louver panel has 2 screws or is snap fit. only other thing it might be is defrost timer
Jun 01, 2009 | Maytag PTB2154G Top Freezer Refrigerator
Side by side Maytag frig that is warm on top, not bottom
You can turn the thermostat off for now to let the ice thaw out, if a door was left open there might not be anything wrong, but if it freezes up again sounds like you might have a bad defrost heater or defrost limit. Hope this helps
Apr 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
The refrigerator isn
If you allow the refrigerator to completely defrost by unplugging it and leaving the doors open, the coils (which are hidden from view usually behind the back interior wall) will allow air to flow around them once again ( after the heavy ice buildup melts away ) It usually drains down into a pan under the refrigerator . This is what contols the temp in the cold portion of the refrigerator. Likely the defrost coils have quit working. This is a common problem and requires a new defrost coil be installed to keep the ice from building up on the coils.
Apr 18, 2009 | Refrigerators
Frig not working but freezer is
check and make sure you dont have frost on the back wall of your freezer on bottom and make sure fan is working
Dec 29, 2008 | Maytag MCD2257HES Side by Side...
Refrigerator side of my side by side to warm
Check the back wall of the freezer section for signs of frost buildup. Your problem could be caused by a frozen evaporator coil in the freezer section. After making your check come back and give the model number of your Maytag .
Jul 03, 2008 | Maytag Refrigerators
Freeaer and refrigerator warm
Check and clean the condenser coil in the back behind a removable panel. after cleaning make sure you replace the panel. Check the back inside wall of the freezer compartment for frost build-up. If there is frost on the back wall you have a defrost system problem.
May 23, 2008 | Maytag Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
46 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
