The power to my RCA HDTV isn't coming on. I hear the normal low-pitched sound that's always running, but the picture and sound don't come on. I've cut the power supply trying to reset the system. That doesn't work.
  • 8,617 Answers
Will need the model number of your set in order to offer any assistance
Posted on May 08, 2008
RCA HD61LPW42. No picture/sound.
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Sep 12, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
No picture but sound
most likely the color wheel needs replacing.
Aug 08, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Rca hd52w59
ok does the set show a picture durring this whinning
i have ran into this problems .. sometimes it has to do with a coil that is oscillating...ll037 or ll029...the fix for this is simple if it is the problem. dampen the coil with silicon.
Mar 26, 2008 | RCA HD52W59 HDTV Projection Television
Low pitched grinding or groaning noise
Dan i recently had one of these in the shop and discovered a problems with blown capicitors in power supply.. however the low pitch groan indicates a fan or what is known as a color wheel. if this motorized part does not reach speed the lamp will not fire. replaceing the color wheel is not an easy task.
Dec 24, 2007 | Mitsubishi WD-52525 52" Rear Projection...
2005 RCA HDTV
Ok. no U can hear the audio for the channels?... this set has no bulbs to replace. does it shut down. does the front green light flash. if u push menu on remote does anthing come up?
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
High Pitch Sounds
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Jun 25, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
