Question about Sony RCD-W1 2-Disc CD Recorder
The tray will not open/eject on either deck; it tries to open but just says TOC no disk.
  • 3 Answers
I have the same problem with both trays on a Sony RCD-W3 not ejecting. If you push the tray sometimes it opens, but takes a few attempts. the recording CD sometimes doesn't see the disk but ejecting and re-entering it normally gets around that. I have no permanent solution, I'm afraid. Probably needs to be opened up and rails greased/oiled or something like that.
Posted on Dec 10, 2010
XBOX360 disk tray keeps ejecting
This is likely the same issue occurring when the disk tray will not open either. Suspect your drive belt is worn and requires servicing. This is best done by an xbox servicing agent. Not too expensive. I have been suffering with a tray that will not open for over 2 years now, however, I am able to fix it simply by ensuring a disk is always left in the tray. It only fails to open if there is no disk in the tray. Even then, I can open it by lifting slightly with a paperclip.
Jul 18, 2014 | Microsoft Xbox 360 Console
Tip
DVD player in my home theater system won't eject the disk inside.
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be disassembled to remove the disk.
on May 04, 2009 | Philips HTS3450 System
I went to put a game in the xbox to play,I waited for it to load & nothing happened.The screen said open tray.I waited & waited but nothing.I pressed the green button on the controller but the tray...
Well you may be having disk tray issues, sure hope so as compared to a burnt out lens module,try ejecting the tray fully and wiping all dust off around the grooves under the tray,one more tip is to keep a disk in the drive at all times, even when you aint playing it, you can also try giving it a gentle tap on the front pat where the disk tray is located any time you eject it or push the tray back in, come to think about it if you are fond of pushing the tray in after inserting a disc, stop cos it weakens the motor that drives the ejecting process, hope this helps...
Oct 25, 2010 | Microsoft Xbox 360 Console
Hts 3450 home theatre system- dvd in player- but won't come out
Unplug power cord.
Plug back power.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Dec 10, 2008 | Philips HTS3450 System
The tray won't open. There is a disk in the tray and I was able to play it back. But, when I tried to eject the disk, the tray woudn't open.
something like this is a physical problem. you should contact the manufacturer to see if there is a manual eject button and if not you will have to take it apart to get the disk.
Oct 29, 2008 | Lite On LVW-5005 DVD Recorder
TOC ERROR ON DENON DN-C615
Take this info with a grain of salt. I recently received one of these units with a TOC error, and after removing the drive assembly and reinstalling it, the problem went away. Before removal, I observed the motor spinning poorly and even backwards. Rather than pull the whole drive assembly, I would first eject the drive and remove the face from the tray. This is done by putting your thumbs on the tray and pulling up with your pointer fingers underneath the face. It should just snap off and snap back on the same way. Try playing a disc now, if it works try loosening the screws on the drive assembly and shifting the assembly towards the front of the unit, tighten the screws and put the face back on. You should be good to go. There are four screws holding the assembly down, the two in the back can only be accessed when the tray is in the open position. The front two are accessible through holes in the tray, and I don't recall if the tray has to be open or not, but that's easily observable. If it's still not working, there is a flat-flex cable running to the laser assembly. Pull and reseat this gently. Try to only manipulate the cable by the blue reinforcement tab. I hope this helps!
Aug 26, 2008 | Denon DN-C615 CD Player
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Toc error
i have had the same deck for four years and installed and removed from 4 different vehicles. the deck has been through some stuff lets put it that way. mine does the same thing as yours, i have found that you just keep ejecting the disk untill it reads. usually only takes a couple times and then mine works just fine.
May 26, 2008 | Kenwood KDC-MP828 CD Player
DVD tray will not open
Unplug power cord.
Plug back power.
Feb 25, 2008 | Dual Presidian DVD Recorder
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Sony RCD-W1 2-Disc CD Recorder Logo
491 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
