Question about Motorola Mobility W315 Cellular Phone
What does Inval Battery mean when displayed on my screen?
    Genius:
  • 1,456 Answers
This means your battery isn't properly inserted or the battery is not the specified battery for that phone model..
Open the user manual for your phone and look up the battery information. The exact battery model number is listed here. Compare the model number to the battery you are attempting to use. If the model number is different, you are using the wrong battery.
If you are sure you have the right battery,remove the battery case from the phone Look on the battery for a white piece of adhesive with installation instructions. On the adhesive it states which side should be facing away from the phone.
Slide the battery into the phone following the instructions given on the battery. If you attempt to slide the battery in upside-down or flipped over the phone is not going to power on.
Posted on Aug 31, 2010
My hp mini 210-1000 boots up well both on battery and adapter but it displays faintly on battery while it display well on power adapter
the problem is that its set in the power saving options. i mean on battery its set to power saver . while on power adapter it changes to hp recomended or high perfomance. So if you want to change it go to the right bottom of your screen and click the battery symbol it should give you the option to 1> change screen brightness 2>more power options. Go to more power options and select "change plan settings" beside the power saver.(not the one beside the other options) and change ur brightness. but its always better to keep it at ur minimum(with what ur comfortable) as its helpful to save battery
Jan 10, 2013 | HP Mini 1000 Netbook
HOW TO USE text.formatDouble in java
You can use these calls:
formatDouble(double inVal, int inDecs, int inLeftOfDec)
formatDouble(double inVal, int inDecs, int inLeftOfDec, boolean recursing)
inVal - double number to be formatted
inDecs - minimum significant figures
inLeftOfDec - number of fixed decimals
As far as I remember java, you use it like this:
String s;
s.formatDouble(34.5566, 2, 3);
Oct 07, 2009 | Computers & Internet
My ccalculator won't graph anything. I get the error messge Inval
Press the 2nd button, then the plus button, then 7, then 1 and then 2. This will reset your calculator to factory settings
Jul 23, 2009 | Texas Instruments TI-84 Plus Calculator
New phone won't turn on just has "Hellomoto" screen
hi.there...don't worry.. what happens with your new cellphone..is normal..why? when your battery is low and there a pop up screen at the display "battery low...please recharge" that's mean you must charge the battery soon.
when connect your phone to charger adapter and your battery is very low / weak condition the display only showing "hellomotto" and nothing else. but it's normal! diplay need more power from you battery to showing all information.after the battery reach the minimum power to display it ( usually after 15-20' charging) try to push red bottom at your keypad phone and the display will showing again..good luck..
Feb 02, 2009 | Motorola Mobility RAZR V3
Display screen says "invalid battery" All works fine, what does that mean?
your battery may be putting off an incorrect amount of voltage to the phone, and powering it on (yes) but frying it internally (no!)
Meaning, the battery may make it work, but it is not good for the phone.
NGK
Nov 03, 2008 | Motorola Mobility TracFone® V170 Cellular...
Motorola Mobility W315 Cellular Phone Logo
122 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
