Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer runs most of the time.
  • 1,531 Answers
These freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Posted on Sep 01, 2010
T-49F Thermometer
you are right but you should read the catalogue.
Mar 04, 2013 | True Freezers
Kenmore upright freezer. Ice cream soft. Food is cold. HELP!
Ice cream has to be colder than 0 degrees C /32 degrees F. You need a cheap thermometer If your Ice maker Ice is not sweating in the bin, -10 degrees F ice stops sweating. you need not to sweat the freezer untill your cheap freezer thermometer can be compared to -10 degrees F
Nov 29, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
New freezer set on 4. Runs a lot. Could we raise setting safely.
Yes you can raise the setting if you'd like. The rule of thumb is to raise it one number and allow it to adjust for 24 hours to see a change in internal temperatures. Freezers can run more for several reasons. One is the amount of product inside- the more the merrier. More frozen food will hold the temperatures longer. Another common issue is location, my own freezer is located in the garage at my house and runs quite a bit in the summer, as the temperature outside increases the lenght and frequency of the freezer running will increase. Freezers transfer the heat they remove from inside the box to the outside of the box, so the warmer it is outside, the longer they have to run to do the job.
Also be sure to keep a good eye on this, keep a thermometer in it and make sure you are not having to turn it way up to get it to "0 f" at least, as you may have a sealed system problem. Real ice cream (not fat free or sherbert) is a great indicator of temperatures- at 0 degrees f. real ice cream is firm but scoopable, 5 below and it's pretty hard, 5 above and is't starting to get soft on the outside.
Hope this was helpful to you!
Jun 26, 2010 | Freezers
Ice Cream Dipping cabinet running but not working?!
Ice cream needs to be below 0 degrees. It sounds like you have a refrigeration problem. The unit runs constantly because the temperature control is never satisfied. ;)
Jul 13, 2009 | Freezers
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
908 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
