Question about Coleman Powermate Powermate 5000W Generator
HI,I ONLY WANT TO KNOW WICH OIL TO USE IN MY EF6000 YAMAHA GEN SET
    Scholar:
  • 97 Answers
10w30
Posted on Sep 01, 2010
Economy switch not working on ef6000
start engine with no load first and warm it up , they run high rpm about 2400 or more with no load..
Mar 26, 2016 | Yamaha Electrical Supplies
Model ef6600de. How do I decrease rpm?
Search Results
    [PDF]EF4000DE, EF5200DE, EF6600DE, YG4000D ... - Yamaha
    www.yamahamotorsports.com/assets/.../0/LIT-19626-01-15_1425.pdf
    Generator. LIT-19626-01-15. 7WV-28199-11. EF4000DE. EF5200DE. EF6600DE ...This manual will provide you with a good basic understanding of the operation and .....card listing your Yamaha model name, engine ... rpm. NO OTHER ADJUSTMENTS NEEDED. ENGINE OIL: IDLE SPEED: ..... Electric Starting Model:.
    [PDF]yamaha generator theory & diagnostics guide - Gen-Tech
    www.gen-tech.net/fullpanel/uploads/files/theory--diagnostics-guide.pdf
    Yamaha Generator Theory and Diagnostics Guide .... Conventional EF6600DE . ...models with Smart Throttle) do not rely on rpm to ... unit manages functions such as AC power modifica- ... tions means higher fuel economy at lower outputs.
    Yamaha Motor Canada :: Products :: Power Equipment ...
Dec 25, 2015 | Yamaha Electrical Supplies
Oil coming out of were water goes in on leg of yamaha 15 horsepower outboard why is this so ???
If your water pump has failed it could be that your lower shaft gear oil is getting past and running out.
The water pump on those should be replaced yearly. They are a rubber wheel with fins on it. They dry out and weather rott wich leads to their failure.
Aug 23, 2013 | Boating
Find paint code
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha Motorcycle Paint ColorRite
Find the color code of your Yamaha Motorcycle
http://www.ebay.ie/itm/YAMAHA-V50M-V80-SUPPLEMENT-SERVICE-MANUAL-1978-1st-EDITION-/371801503817?hash=item569118b849:g:9-AAAOSwOyJX3pVB
YAMAHA V80 80 GEN PARTS CATALOGUE MICROFICHE 1980
http://www.ebay.ie/itm/YAMAHA-V50M-V80-OWNERS-MANUAL-PART-NO-2J6-28199-21-/371810900410?hash=item5691a819ba:g:OlMAAOSwZVlXrbc6
Aug 06, 2013 | Yamaha Motorcycles
Can you help me? I have generator yamaha ef 2600. Generator normally running about 3 minutes then rpm comes unsteady and gen stops. Moreover at load 2kW gen immediatly works unsteady and stops. Without...
As you describe the problem, the reason is unstable load handling.
This means that the fuel or air is not enough.
When begin to be unsteady:
  1. If smoke comes out of muffler - the input air is not sufficient. Try to clean or change air filter (cleaner).
  2. If no smoke, the fuel is not enough. The reason may be the mechanical governor, or the fuel supply to it, fuel filter/strainer etc.
Aug 05, 2010 | Yamaha 2300 Watt Generator - EF2600
Bike wont start
that shouldn't stop it from starting unless they were hanging out. in wich case you wouldn't be able to kick it over. you would see signs of oil leakage too. do you have fresh gas and good spark at plug?
Apr 02, 2009 | 2003 Yamaha YZ 125
Gen,set 2500w
Hi, Surely that is the correct output? Gensets usually put out 240 and 110 or just 110. Alan
Jan 02, 2009 | Yamaha 2500 Watt Industrial Inverter...
Coleman Powermate Powermate 5000W Generator Logo
79 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
