Question about Ecoquest Flair Air Purifier
My fan won't work. It has not been used much at all
  • 99 Answers
First, unplug the unit from the wall. There is high voltage inside the unit, so use caution.
Next, check the fuse on the back of the unit. If it is good, then you need to check the fan.
Corrosion can build up on the interior of the fan assembly. Remove the filter and look for the connections at the bottom of the fan motor. Make sure they are not loose, corroded, or disconnected. If you have a meter you can use to check the voltage, or know someone who can, see if voltage is being applied to the fan. You will need to plug the unit back in, so remember the high voltage on the screen, and on the needle emitter at the front of the unit. If voltage is present, you can go to the Alpine web site and order a replacement motor. This is a common failure item. If there is no voltage, the unit will need repair.
Posted on Aug 31, 2010
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
Aug 07, 2014 | Lasko 2510 36" Tower Fan with Remote...
My fresh air 2.1 won't go into away mode. I
Fresh Air purifiers are noted for two weak points. The display circuit board and the main circuit board. Call (336) 499-2505 and they will help you work through the problem. They give away information.
May 25, 2012 | Ecoquest Air Purifiers
Pure pro fan motor
compressed air , you might try bringing it to a electric motor repair shop or a auto shop and ask real nice if they would be nice enough to give your fan a shot of air. a weed blower will work also but not even close to the job of compressed air. last resort is to take it apart totaly and use soapy water and a scrub brush. do not get the motor wet ! and oil the bearings on the motor with zoom spout oil #D01.. and you can milk your favorite fan out for many,many years .. this way is like cheating death! ... jay the pool pump motor repair guy in longwood fl
Jan 12, 2012 | Montgomery Ward Pure Pro Air Purifier
I have a 42" wind
the first thing to check is that the remote control is working and the control panel of the fan itself are working probably and i think they did but you have to check first
this fan oscillating control button is not a mechanical connection like the regular fan so if you are not using it wrong(and i think you don`t ) an if all the buttons are working -except the oscillating function - (and i think they are ) turn that thing back and test it at the shop
May 22, 2011 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
Power won't come on switch does'nt lite up fan does'nt work
First, are you sure that outlet that the unit is plugged into really works? The other situation would be a blown fuse on the back of the unit. Also, make sure that the filter on the back of the unit is seated properly and making contact with the safety switch. Check all three things. It could be any of them.
May 13, 2011 | Alpine Air Eagle 5000 Air Purifier
I cleaned my Flair air purifier, The motor turns on but not the fan even after lubricating the fan shaft and giving the fan blades a little push. Any suggestions on how to get this going?
The Flair is no longer manufactured nor serviced by EcoQuest, and the company is now Vollara. If what you're hearing is the fan motor (there is no other motor associated with this machine), it might mean that either it's totally seized up, or that the oil just has not penetrated deeply enough.
1) Turn the machine over and remove the large screw in the bottom. The chassis will then slide out (I assume you've already done this in order to reach the fan shaft.)
2) Firmly pull on the fan blades near the center in order to pull them free of the shaft.
3) Turn the chassis on its back, so the fan shaft points up. Drip a small amount of lightweight oil (sewing machine, hair clipper, 3-in-1) on the shaft and turn it manually to work the oil down the shaft. Continue doing this if you feel the shaft loosening up.
4) Set the chassis upright, tilt it forward, and drip a small amount of oil on the rear opening to the fan shaft. Continue manually turning the shaft and tilting the machine to work the oil in.
5) Replace the fan blades and turn on the machine, depressing the safety switch manually, to see if the fan will begin to turn.
If it won't turn, it might mean that the fan motor is entirely seized up. You may be able to find a local small appliance repair person who could replace that motor.
Your other option is to call Vollara customer service at 800-989-2299 and ask them to explain your options. Use #16618 if you need a dealer referral number.
Feb 11, 2011 | Ecoquest Flair Air Purifier
Everything works but the fan will not turn. I recently performed a thorough cleaning and installed a new ozone filter, but the fan will not turn. I tried turning the fan manually and the unit would run...
The fan needs oiling (except for the Fresh Air, which has sealed bearings and no removable front grid). I need to know which model you have to help you reach the fan shaft. However, if you're handy, you can figure it out. Remove the front grid (if there is one on your model) and pull off the fan blades. Use a light household oil (sewing machine, hair clipper, 3-in-1) to drip down the shaft as you turn it manually. This should take care of the problem.
If not, and if you need more extensive repairs or rebuilding, call Vollara (new name for EcoQuest) customer service at 1-800-989-2299 and use 16618 as your dealer referral number.
Jan 30, 2011 | Ecoquest Air Purifiers
Fan blade broke
Remove the 4 screws on the front grill. Grasp the fan with both hands and pull the fan off. Kind of prying it out using your hands as levers works best. It may be stuck if you have never removed it for cleaning, which you should do, periodically. The new one slides on flush with the end of the shaft.
Mar 30, 2009 | Ecoquest Breeze AT Living Air Purifier
Alpine XL - 15 Fan Stopped Working
Hello again, night light,
I don't think you hurt it by nudging the blades - I have one where it does the same thing unless I have it set on "max".
The challenge is that I don't know which is more likely the problem - I haven't worked much with the electrical aspects of them recently - - I might have to try working with one, although it may vary between models - the one's on the circuit board would be harder to swap-out. What was the vintage of yours again?
Good for you on having a multimeter, and being willing to learn to use it!
All I was talking about earlier was using the CONT (continuity) function to check for a circuit (some models have a little buzz or beep that sounds when you have a connection. If you have the fan pot. wide open, you should be able to get a good signal between the terminals of the pot.
Another option - crude, but effective - would be to "jumper" (short-circuit) the fan terminals (at the pot.) together to see if it runs with the pot. bypassed out of the circuit. This shouldn't harm the motor, and if it still doesn't work, that points to the motor being bad. As always, use common sense and be safety-concious, don't bypass the safety cut-out switch or the like.
I may have to check with one of my brothers (biomedical electronics tech.) for a little additional guidance - - he could probably give me better insight without spending a lot of time on trial-and-error. If that happens, I'll follow-up with another Solution entry in the next few days.
If I can be of further assistance, or if you have additional questions/comments for this item, please let me know.
If/when this solves the issue to your satisfaction, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Dec 28, 2008 | Alpine Air XL-15 Air Purifier
Alpine XL-15 fan has stopped working
Hello night light,
How you proceed is going to depend on how comfortable you are taking it apart.
Given it's age and purchase condition, warranty isn't an issue. You will either be able to dis-assemble the purifier and try taking the motor apart and reassembling, or you can find a replacement motor (I've seen some on the web, they start at ~$50).
Another possibility is that the fan pot (the rotary switch that the knob turns to adjust the fan speed) may be out. If you have a multi-meter, see if you can get a signal through (when it's all the way open). If not, try replacing that first. Parts are available onthe web, I can't advertise per FixYa's terms of use.
Hope this helps.
Sep 28, 2008 | Alpine Air XL-15 Air Purifier
Ecoquest Flair Air Purifier Logo
83 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
