Question about Cameras
Kodak m883 will not charge.
I ordered my Kodak M883 and recieved it yesterday,but the battery will not charge.I went and bought the UBS adaptar and still will not charge.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey Kovue,
If you just got this camera and the battery won't charge right out of the box you have a few options. You could have the battery replaced by Kodak, and the battery model # is
KLIC-7006. You are most likely within your return/ exchange period, and you could just bring the camera back to the retailer and exchange it for a new one. Unfortunately with the number of camera's the manufacturer makes they do sometimes produce a defective product. Your camera not charging could be due to a bad battery, or it could be due to a problem in the camera.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 09, 2008
Kodak M883 will not accept charge when plugged to computer and will not go on either when plugged to computer.
Not all computer USB ports put out enough current to charge batteries.
If you're connected through a hub, try bypassing the hub and connecting directly to the computer. If you have another USB port available, try that. If you have a USB charger that plugs into a power outlet, try that.
Feb 15, 2014 | Kodak EasyShare M883 Digital Camera
Why is my battery not working
first thing I have to ask is did you put it in the right way.
Jun 22, 2013 | Kodak KLIC-7006 Battery + Charger...
Digital camera M883 operating manual
Getting Started Guide:
http://support.en.kodak.com/app/answers/detail/a_id/18849/kw/m883
User Guide:
http://support.en.kodak.com/app/answers/detail/a_id/18846/kw/m883
Nov 30, 2010 | Kodak Cameras
Replacement manuals and charger
You can download a PDF version of the manual and order a battery charger from http://www.kodak.com/global/en/service/products/ekn032921.jhtml?pq-path=11249/11251 for the M853 and http://www.kodak.com/global/en/service/products/ekn034144.jhtml?pq-path=11254 for the M883.
May 15, 2010 | Kodak EasyShare M853 Digital Camera
Kodak Easyshare M883 overheats when battery & camera is off
There is a dead short somewhere within the battery holder, replaceing the battery will not fix it It will require intervention by a technician to uncover and fis the short circuit or bare wire. Check out the minimum repair cost and compare it to replacing with a newer model. It may well be throw away.
Please rate my help++++Thankis for using FIXYA
Apr 20, 2010 | Kodak EasyShare M883 Digital Camera
Kodak M883 can't see pictures
This is perfectly normal. When charging the camera cannot display pictures on the LCD.
Dec 03, 2009 | Kodak EasyShare M883 Digital Camera
My m883 turns on for 1 second then shuts off??
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 18, 2009 | Kodak EasyShare M883 Digital Camera
My kodak m883 green light flashes when turning on
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Here are the steps:
Contact KODAK:
Nov 17, 2009 | Kodak EasyShare M883 Digital Camera
M883 Powers on then off ?
Check if there is ample space on the memory and good charge on the battery and try, if it still persists then there is a fault on the lens moving out and in, probably because u wud have dropped it.
Thankyou
Jul 31, 2009 | Kodak EasyShare M883 Digital Camera
Cameras Logo
142 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
