Question about Gestetner Copier
Printing Problem - Help
When i send my document to print, it keeps being picked up by the bypass tray instead of the default tray. Ive checked all my settings on the computer, but nothing has resolved the issue yet. Please help.
    Novelist:
  • 158 Answers
N your computer, left click on START, left click on CONTROL PANEL, then left click on PRINTERS. On the PRINTERS SCREEN, RIGHT CLICK on GESTETNER icon. On the drop down menu, left click on PROPERTIES. Left click on ACCESSORIES tab. On the paper source setting, select TRAY 1 LETTER as the default paper source, left click on UPDATE, then APPLY, then OK.
Posted on Aug 11, 2008
Printer is only printing to the bypass tray instead of tray 1 where it should be printing
First, check your printer properties and make sure you are not telling it to go to the bypass tray.
If you are set to auto tray and its still trying to pull out off bypass tray. Check on the copier to make sure tray 1 isn't set for a special type of paper. If it is, change it to plain paper.
Sep 30, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Will not double sided print as book
Sorry unfortunately I can not figure out what is going wrong here. It could be the way MS word is sending the document to the printer, the only thing I can think of is that it may be that you do not have the page setup of the document set to legal. There may be something in word that also allows you to send the document to the bypass tray as opposed to the default tray.
Nov 29, 2011 | Toshiba e-Studio 200 All-In-One Laser...
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Hp 4250 manuall feed heavy paper message
You'll have to set up the paper settings within the copier to reflect heavy paper for the bypass tray. You'll need to make this a default setting. Then when you print out with heavy paper via the print drivers it should pick up automatically at the printer.
Aug 28, 2009 | HP LaserJet 4250n Printer
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Cannot send a p rint job to pring labels from word to bypass tray with Canon 5000 copier Click on copier properties, click on bypass tray and then ok and print. Will not print fromt he bypass tray Ideas?...
If you can copy from the bypass, you should be able to print from it. It may be a setting in the print driver. Not the one you use through windows but the one installed in the printers folder in control panel. Check that it is not set to draw 1 - it should be on AUTO. Also, the document you are using has print settings of its own - check them as they will overide the tray you select. Select from within your document file - options - printer then look through those settings and anything telling the machine to print to a particular draw will make your job go there instead of where you ask it to.
Jul 09, 2009 | Canon imageRUNNER 5000 Copier
Print to bypass
Before printing click the property button, go to papar tab, under tray select, change from auto select to by pass tray
May 19, 2009 | Sharp MX-2700N Color Copier
Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
-Carl
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
TRAY SELECTION
I cant using bypass tray for printing. I set A4 for paper size to every places. But it tells the papersize is mismatch?
Jan 14, 2009 | Toshiba e-Studio163 Copier
Ricoh CL3100N
Have you setup for double-sided printing?
Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
152 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
