Question about Whirlpool Refrigerators
Tempature not cold keep a little warm - Whirlpool Refrigerators
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 31, 2010
Having a problem with tempature gauge jumping up and down from hot to cold. I have change the coolant tempature sensor and 1week later it started this.
Chevrolet Venture Questions - My thermostat gauge in the ...
www.cargurus.com > Questions > Chevrolet > Venture
CarGurusOct 2, 2014 - My thermostat gauge in the car is going up and down, what could be theproblem - My thermostat starts on cold and when i get in and drive it goes from low .... low to almost hot., and it jumps back and forth when I drive the car.
Temperature gauge shot up - Bimmerforums
www.bimmerforums.com/.../showthread.php?...Temperature-gauge-shot...
Nov 30, 2010 - This morning I had a problem starting the car as it was -22F and when I finally started it my ... Now the temperature gauge still jumps right to the red zone (all the way to the right). There is no way that this is right as the engine is cold. ... Even if it were stuck closed, it would take a while for the car to warm up.
Car Repairs: Coolant Temperature Gauge - YouTube
? 7:47
https://www.youtube.com/watch?v=fWjPX0_ibxY
Apr 15, 2012 - Uploaded by TheYoshiClan
... Caprice/Olds Delta 88 owners. If your coolant temperature gauge isn't working, check this out before heading out to get replacement parts. ... the car is barely getting warm inside. What seems to be the problem if you know?.
My car temperature gauge keeps bouncing around from cool to red ...
https://answers.yahoo.com/question/index?qid...
Jan 11, 2016 | Cars & Trucks
My Fridge is not having the tempature to cool the food and the freezer is not freeezing the food but t is cold enough to keep my milk cold. I left my milk and water in the freezer and it didn't freeze...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | Refrigerators
2001 Alero- heat gage does not show heat tempature. Blows warm air.Engine felt cold after a 50 mile trip. Out side tempature 20 degrees fernaheight.
with winter being here you might want to consider having a new thermostat put in to increase the heat in side,but make sure your radiator is full when engine is cold
Dec 26, 2009 | 2002 Oldsmobile Alero
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
No Heat in 99 Taurus
Just finished fixing my daughters 1999 taurus heat. It would blow warm only when running down the road. At idle it blew cold. I started with replacing thermostat, and water pump because they are the easier fix. Still did not help. Then I replaced the heater core. A daunting job but not that hard to move the dash slighly out of the way to replace. There is a good write up at tarusclub.com. After that, heat was better but at idle, it would still blow cool sometimes. Researched and found answer. Park car on the steepest hill you can find with front of car up. Start car and take off reservoir cap. Let car warm up and keep rpms about 1500. After a while the fluid will come running out of the car and all over the place but it will bring air bubbles with it. Reduce rpm, add more fluid and repeat about 3 times. It will make a mess but after that, the heater works perfectly. We get heat long before the temp gage indicates any and it never blows cold unless you lower the temp.
Nov 21, 2008 | 1999 Ford Taurus
Over tempature reset keeps beeping
its registering a warm temp, you reset it but when it checks again in 2 hours or so its still seeing a warm temp whichi s why the alrm is going off, id look at the contents of the refrig for signs of defrosting, icecream not hard enough, ice maker not producing and melting, moilk spoiling premature, butter too soft.
Nov 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
2003 F.I. Softail
Sounds like a mapping issue with whatever f.i. add on you have. could also be the pintle sticking on the throttle body. take the air cleaner off, look at the inside of the throttle body. at the top there will be a little hole. that's where the pintle is. it retracts and expands for cold starting and hot idle as well. if you turn the bike on and off it should cycle. ( extend and retract ) if it doesn't then the pintle needs to be replaced.
Sep 08, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Refrigerators Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
