Question about Dell InspironTM XPS M1210 Notebook
When I turn on my latop computer, the screen is dead. I tried to run the laptop with an external monitor. when I plug an external monitor into my laptop and it works. What is the problem?
  • Dell Master
  • 4,924 Answers
There are 3 posibilities...either the lcd is gone ...and in this case you need to replace it ...or the connection ribbon it either damaged or it is out from the plug ...or ..there is the 3rd possibility what the laptop is on the external monitor set-up ..and in this case you have to enable from the video driver the no1 monitor ..,,just plug the external to have control ...and press the Fn key ..and the f key with the monitor symbol on it ..usually it is the f4 key ..but pay attention onthe symbol and that it is the hot key for enabling and disabling the monitor ..
Another thing you can do is to go to bios by pressing the F2 key on start ..and there engage the optimal factory defaults..and confirm ..and save changes by pressing the F10 key ..This should reenable the monitor if it was disabled by mistake ..
Another thing to keep in mind..is that even disabled the monitor should flash at least the logo on start if it is still functional ..if it is doing nothing at all.than it is damaged..and need replace ..
Posted on Sep 01, 2010
My screen doesnt work. it stays black when i turn the laptop on
If the laptop sounds like it is running and you have no display you can try to plug in an external monitor to it. (any computer monitor will work, just plug the data cable in to the blue VGA receptacle on the back or side of your laptop). Turn on your laptop and look at your function keys on the keyboard. One will have a monitor symbol (maybe F4). Push that function key to switch to external monitor. If it displays on the monitor then you know your computer is okay and that the problem is with your LCD screen. If there is no display then most likely you have a bad video chip on the motherboard and will have to replace the board.
Apr 07, 2011 | Acer Computers & Internet
Fujitsu lifebook screen will not come on
Could be a dead screen, use your vga, hdmi or svideo port to an external monitor or tv, if you get video there, then your laptop is still working and it is your screen. Check to see if you see any pictures on your screen but it would show in really really dark picture... if that is the case it is your screen backlit bulb that gone bad and the screen will need to be replaced. If nothing appears on your screen but you get picture to a external monitor via s-video, hdmi or the vga port then it could be that you have a loose cable connection or bad wireing somewhere between your latop base and the screen. If nothing at all appears on your screen or the external monitor source then you have a promblem with your laptop.... and those promblem can be in a wide range of trying to seek out the defective part.
Jan 14, 2011 | Fujitsu LifeBook S6520 Notebook
Hi , i was working on my computer and all of the sudden it went dead and its turns on but in the booting process the screen goes black
sounds like a failed backlight,
try plugging into an external monitor (you may need to use the function + change monitor key to switch to external monitor)
Aug 03, 2010 | Toshiba Satellite Pro L300 Notebook
I turned on my laptop the lights came on heard the fan breifly. The screen stayed black and never turned on. The laptop just kept turn off and on every few seconds. It is plugged into the outlet. What is...
has it been recently attached to a docking station, or a external monitor?
I do not have a Presario Compaq handy, but on my Dell, the key combination to change monitor outputs is Fn + F8.
If you can see which of your keys on your laptop keyboard switches the video output perhaps that might bring it to life.
but it might be more than that. is it that the computer is dead? no beeps, fans or activity? , or does it have all that, but no screen output?
try plugging in an external screen if you have the opportunity, and see if it shows anything.
Jul 10, 2010 | Compaq Presario Notebook
Unable to view screen - computer starts up and no lcd usage. I tried connecting another monitor and doesn't work either. Could it be the video card. Thank you!
Press the combination keys Fn+F... key that switches on LCD or external monitor. If that solution does not work...it means that your video card chip is dead.
Feb 14, 2010 | Dell Inspiron B130 Notebook
Whilst in use went completly dead canot resart
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Nov 02, 2009 | HP Pavilion dv6000z Notebook
My laptop monitor is not woking
Oct 16, 2009 | Computers & Internet
CPU On Monitor Dead
The monitor, since it is under warranty is best to be examined by an authorized personnel or replaced. As for your laptop, I dont suppose it has a problem. Only that it should have been configured to send display to the external source once plugged.
There are 3 options
  • Native + External
  • Native alone
  • External alone
Your laptop is configured for the 3rd option. You can change this by getting into display properties and under your graphics card configuration. Please do comment if you need further assistance
Jul 25, 2009 | Westinghouse L2046NV Monitor
Toshiba L20 - screen appears dead?
Try to plug in an external monitor on laptop to check if there is a problem with your LCD.
Plug in the external monitor then boot the computer. If still nothing happens try removing the battery and the adapter, let it rest for a minute then plug in only the adapter and try to boot up with out the battery.
Hope this helps.
Sep 13, 2008 | Toshiba Satellite L20-S310TD Notebook
Monitor not showing anything
Man your toast. Google JB Technologies, they specialize in laptop repair. Good thing you admit the water thing b/c alot of latops have a special chem on the motherboard that changes color if exposed to water or liquid.
Jul 29, 2008 | Toshiba Satellite M45-S165 Notebook
Dell InspironTM XPS M1210 Notebook Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
