Question about Viking VGIC365-6B Gas Kitchen Range
Turned on oven to 400. When opened door no heat. Checked that I had turned the right knob and saw the oven light doesn't come on either. Ugh!! I need my oven. All six burners work but need to be lit with a match. The self ignite works sporadically.
  • Viking Master
  • 43,501 Answers
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Aug 31, 2010
  • 1 more comment
  • SeanNY
    SeanNY Mar 19, 2014
    I think he is wrong. The ignitor going bad shouldn't affect the ignitors on the stovetop and definitely shouldn't put the light out
  • SeanNY
    SeanNY Mar 19, 2014
    I googled this because I have exactly the same problem. Oven electrical shuts down when I use the stove and then a day later it's fine again.
  • SeanNY
    SeanNY Mar 19, 2014
    I also noticed that my oven door gasket is damaged and there is a lot of heat and moisture escaping from the oven when it gets up to temperature. So my guess is that the moisture escaping is wetting the circuit board and shutting all the electrics down. Then when it's dried out the next day, it works fine again.
What is the worst that could happen if an electric double oven ceramic hob had the neutral and earth mains power wired the wrong way round ?
Electronic controller would most likely be damaged and need to be replaced. These things usually cost between $350-$400
Nov 28, 2014 | Ovens Ovens
Oven doesn't heat up and no light symbol shows up on the indicator panel.
it sounds like you tod stat has gone if you turn the oven off from the mains pull the oven right out and take the lid off you will see a little black stat with two wires join then up together do not let them tuch any thing then turn the oven back on if it all works afther you put the time in you will need a new one of them ok hope i have helped you
Nov 03, 2012 | Bosch Ovens
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Whirlpool oven door won't open after self cleaning.
I had the same problem. Hold down any button for 1 minute. That should reset the memory.
Mar 30, 2009 | Whirlpool SB160PEE Gas Single Oven
Self clean doesn't start
i would pop the top up and see if there is a bad switch on the handle that locks the oven.
Feb 13, 2009 | Whirlpool RBD306PD Electric Double Oven
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn Air oven door won't open after clean cycle
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Nov 26, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Older model - belling 356 double oven - unable to get grill to work
The microswitch on the right of the top oven is stuck in. Open the top oven door and you can see the switch on the right. It has a small black rubber cap on it. To solve this, loosen the right top and bottom screws of the brown panel and lever the white panel slightly to the right. Tighen the screws and the switch should go in and out as you push and release it. The grill will now come on when the door is open.
Apr 01, 2008 | Kitchen Ranges
Oven door won't unlock
I fixed the automatic oven door lock on my oven. While the door was open, I pushed the button on the upper left hand side a couple of times (the one that senses when the door is closed.) Then I was going to call the repairman when the door closed! I had to run the self clean cycle again to get the lock light to go off, but it worked!
Nov 25, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Self clean light blinks, oven does not work
You were right. The locking mechanism switch somehow became jammed and the oven thought the door was locked, even though I could open the door. I didn't know if I was supposed to take the top off and moving the lever back and forth did not help. Finally I turned the oven on and just kind of jiggled the latch in the unlocked position. I kind of moved it back and forth furiously and the cleaning light stopped blinking and the oven light came on. I'm glad it is working now, but I will be manually cleaning my oven from now on! Thanks for your help.
Dec 25, 2006 | GE JGBP26 Gas Kitchen Range
Viking VGIC365-6B Gas Kitchen Range Logo
202 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
