Question about Noritz 6.9 Gallon Residential Direct Vent Tankless Water Heater - N
My o69m flashes a 16 and says priority - Noritz 6.9 Gallon Residential Direct Vent Tankless Water Heater - N
    Scholar:
  • 73 Answers
The 16 error code occurs when the outlet temperature exceeds the set temperature of the unit. Typically this occurs when the unit has developed scale in the heat exchanger. I would initially recommend performing a descale on the unit to remove any scale deposits from the HEX.
Posted on Sep 01, 2010
I have a Rinnai RL 175 Tankless water heater. I just moved into the house two weeks ago. We have no hot water. Green priority light and beeping sound came on. Breaker also flipped on panel. Any ideas?
Usually, Breaker tripping indicates a hard short ... probably the heating element is shorted and needs replacement. Possible bad C/B but don't think so.
Good Luck! handy Henry.
Feb 14, 2017 | Rinnai Water Heaters
Beep codes
Get the manual for it on line and look up the beeping meaning and the reaqon for the priority lite.
May 24, 2013 | Rinnai Water Heaters
The Noritz HW Heater has been tripping out some (usually whenever the shower is running, and someone turns on cold water). LED flashing three times. Any Ideas
This is probably a 16 error code. This code indicates the outlet water spiked above the set temperature for an extended period. It usually means the heater needs to be descaled or the manifold pressures need to be adjusted.
Mar 10, 2011 | Noritz 6.3 Gallon Residential Tankless...
I have a Model N-069M and i get a flashing code 16. I just had the unit flushed two days ago and i still get the same code. thanks for any help
I feel your pain. I am experiencing the same issue which started about 3 weeks ago. First it happened twice that first week and we discounted it. Now that my heater has been flushed the same issue is occuring. I called Noritz 3-4 times now and they are saying that I may have high manollowifold pressure and should have that checked.
FollowUp: Plumber determined my Natural Gas inlet line was too small. He Tee'd off before my manifold to other appliances and fed with a 3/4 line. Issue resolved and it has been trouble free since. (Updated 2/2017)
Feb 12, 2011 | Noritz 6.9 Gallon Residential Tankless...
I have a Rinnai MC-45 US. One morning, we had no hot water & the temp on the control panel read 12. So I pushed the Priority button. We now have hot water, but the priority button is still lit. It has...
Error code 12 can sometimes be caused by a short circuit on the low voltage side of the installation. Could possibly be a fault with the controller itself which is low voltage.
Jan 31, 2011 | Rinnai Digital Remote Water Heater Control...
I have a Nortitz natural gas water heater, model #N-063s-1. Acouple of days ago it stopped heating the water. what can I do myself to fix this matter. Thanks, lynnatheana@hotmail.com
There are many reasons a tankless heater will stop heating water. The first thing I would look for is a flashing red light on the burner indicator. The flash break down goes as follows
continuous blinking - typically means ignition failure or the unit is overheating; look for visible water inside the unit, have your gas pressure checked, or check the flame rod/igniter for buildup of debris
three blinks - typically indicates 16 error code; typically resolved by performing a descale
4 or 5 blinks - exotic error codes; for these you should definitely contact Noritz tech support
If there is no flashing light, first check your filter for debris. If the filter is clean, your flow sensor is probably stuck. Again I'd recommend contacting Noritz tech support to help you clean the flow sensor.
Jul 31, 2010 | Noritz 6.3 Gallon Residential Tankless...
Sometimes the hot water just goes cold
Here are a couple things to look for:
1) flashing burner light - a flashing burner light indicates the unit is getting an error code
common error codes:
A. continuous flashing - ignition failure or abnormal combustion; look for visible water in the machine indicating a leak, check gas pressure, debris or buildup on flame rod/igniter plug, or clean unit with compressed air
B. 3 flashes - error 16, abnormal outlet water temperature; typically this code indicates you'll need to descale you unit
C. 4 or 5 flashes - exotic error codes; you should contact Noritz technical support to deal with these codes
2. If there is no flashing code, try increasing the hot water flow. In the summer time you typically use less hot water; this can result in intermittent operation of your tankless heater. Increase water flow by either: A. cleaning your showerhead and removing scale deposits B. widening your flow restrictor C. Remove your flow restrictor in the showerhead
3.If none of these resolves your problem, you probably have debris in your flow sensor. Contact Noritz technical support for a walkthrough on removing debris from a flow sensor.
Feb 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
Wiring a smart control to a taco sr504 to a honeywell L7248.
Set tempture up some so the water will be hoter.
Mar 18, 2009 | Water Heaters
Noritz 6.9 Gallon Residential Direct Vent Tankless Water Heater - N Logo
294 people viewed this question
Top Noritz Water Heaters Experts
gizmonix
Level 1 Expert
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
